| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
May 2012 OTOTM Winner
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
Used For: Daily driver/weekend warrior
Rep Power: 9 ![]() iTrader: (0)
I'm not going in to detail about what happened, all I'm going to say is ice is not my friend and it was a very light roll.
The roof is pushed down about 4" in the middle, but the pillers appear to be fine, the windshield cracked in the middle where the roof came down. The doors are a little messed up at the top, but still open and close. I found a roof off a 2008 thats already cut and ready to be picked up. I've never seen how the roofs are replaced on the regular cab rangers, but I'm going to assume it shouldn't be too difficult. I'm going to assume the back glass has to come out, the seats and most of the trim also have to come out. I watched this video and learned quite a bit, but would like to know more about how to do it on a ranger. http://www.spike.com/full-episode/bl...ar-buick/36421 Any advice would be greatly appreciated.
__________________
1997 SFA Ford Ranger XLT, 2.5L, Black ext/Royal blue Int, Reg cab, Long bed, M5OD, 1354M, Jeep YJ D30 Front, 8.8 Rear, 4.10 gears, 33x10.50x15 BFG KM2's, Too much to list. Last edited by 5speedin2.3; 12-11-2010 at 02:55 PM. |
Tweet
#2 | ||
Tracked and Locked
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (13)
Make sure you know where to get some doors. You might find that they don't close so well once the roof is fixed.
__________________
Project: Hillbilly Deluxe Project: Amazing Grace Project: 12-Volt Sandwich Quote:
Quote:
HELP REPEAL OBAMACARE Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind. |
Tweet
#3 |
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
What do you mean?
I believe there is no structure damage done to the cab. The rollover was very slow and I watched the window slowly crush down the little bit it did.
__________________
1997 SFA Ford Ranger XLT, 2.5L, Black ext/Royal blue Int, Reg cab, Long bed, M5OD, 1354M, Jeep YJ D30 Front, 8.8 Rear, 4.10 gears, 33x10.50x15 BFG KM2's, Too much to list. |
Tweet
#4 | ||
Premium Member
Year: 1995
Make: Ford
Model: Ranger
Engine: 2.3
Class: 2WD
Used For: Warding off gold diggers
Rep Power: 48 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I'm really enjoyin that video man, thanks for posting it up.
__________________
My EX250 build thread Quote:
Quote:
Tweet
#5 | ||
Tracked and Locked
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Sometimes the smallest bit of bend can be enough to mess up the doors. I doubt that you will have any issues, but I've seen enough of these that I just thought you should at least be aware that MAY be an issue.
__________________
Tweet
#6 |
Year: 1985
Make: Duh!
Model: Bronco II
Used For: Everything
Rep Power: 9 ![]() iTrader: (2)
google ranger prerunner roof replacement...its a red ranger, i believe might be a first or 2nd gen. he has a build thread somewhere and goes into detail of doing the same thing. maybe it will help u. im gonna try to find it for u
__________________
85 b2/fm146/bw1350 D'sparked,built, Holly'd 2.8/4" SJ coils/Explorer leaves/3" blocks/ shortened Explorer driveshaft/ 2.5" pivot drops/30x9.50 MXT's/Roofrack/HID's/ Autometer guages Comming Soon:1" body, 33's, LED tail light boxes |
Tweet
#7 |
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
The window is broken from the mirror. The damage is minor.
__________________
1997 SFA Ford Ranger XLT, 2.5L, Black ext/Royal blue Int, Reg cab, Long bed, M5OD, 1354M, Jeep YJ D30 Front, 8.8 Rear, 4.10 gears, 33x10.50x15 BFG KM2's, Too much to list. Last edited by 5speedin2.3; 11-11-2011 at 09:07 PM. |
Tweet
#8 |
Solid Axled yo!
Year: 1999
Make: Ford
Model: Ranger XLT Sport
Engine: 2.5 (5spd)
Class: SAS 4X4
Used For: Everything and more...
Rep Power: 68 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
doesnt look that bad, ive seen worts and they fix them, but replacing it would be the best option, cut and weld a good one, make sure its leveled and at the exact height, or you will have issues with the windshield
__________________
click for: Ranger Sport Honduras Level II (My D30 SAS 4WD) Mini Power Stroke (My bro's Crew Cab 4WD Ranger--Slow build) Ranger Militia Cardomain(All the trucks) |
Tweet
#9 |
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
No one?
__________________
Tweet
#10 |
Year: 1994 Ranger STX
Make: 1995 Explorer L
Rep Power: 12 ![]() iTrader: (0)
I would strip the interior , leaving it drivable , take it to a body shop and have them use the frame machine to straighten the cab and then use the roof you found to skin the roof.
just my 2 cents |
Tweet
#11 | |
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Quote:
http://www.therangerstation.com/foru...ad.php?t=79003 post #9 and #13 I used the doors from one cab with cut lines marked to transfer those cut lines from one cab to the next. I don't think you would be able to do the same. In your case I'd try making a cardboard template that had body lines marked on it from a known good truck to be able to transfer cut lines from the donor roof to your truck. Also I'd probably make the cut lines closer to the bottom or top of the window, not the middle like I did. Good luck, Richard
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein Last edited by alwaysFlOoReD; 12-17-2010 at 04:58 PM. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
