Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 12-03-2010, 06:48 PM   #1
The_Dealer
The_Dealer's Avatar
Year: 1985
Make: Duh!
Model: Bronco II
Used For: Everything
The_Dealer will become famous soon enough
Default cargo lighting, and expo ohc
my b2 doesnt have a rear cargo light, it has the cutout in the headliner and has 2 wires, but no plug or anything else. i would really like to have one, is there anywhere besides a j/y i can get them? what all do i need?
also i wouldnt mind having an explorer overhead console, which year are u guys using? anyone have some pics? i think my b2 used to be electrical tcase because i have a small hole and 2 wires comming out of my headliner where the buttons would have been.
one more thing, how can i run a switch to mount in the cargo area to stop all lights from lighting when any or all doors is open? i like to jam out when im camping and would like to be able to keep the lights off and be able to sit in the back and have the doors open
__________________
85 b2/fm146/bw1350
D'sparked,built, Holly'd 2.8/4" SJ coils/Explorer leaves/3" blocks/ shortened Explorer driveshaft/ 2.5" pivot drops/30x9.50 MXT's/Roofrack/HID's/ Autometer guages
Comming Soon:1" body, 33's, LED tail light boxes
The_Dealer is offline   Reply With Quote
Old 12-07-2010, 07:05 PM   #2
The_Dealer
The_Dealer's Avatar
Year: 1985
Make: Duh!
Model: Bronco II
Default
nobody?
__________________
85 b2/fm146/bw1350
Old 12-08-2010, 05:40 AM   #3
unoleisu
unoleisu's Avatar
Year: 87
Make: ford
Model: BII
Engine: 2.9
Class: 4x4
Used For: Zombie stomping adventure mobile
unoleisu will become famous soon enoughunoleisu will become famous soon enough
Default
As far as the lights coming on when the back hatch is open, I did a temporary fix. The switch at the driver's side of the back hatch sticks out far enough, that I held it all the way in and drilled a small hole all the way through the button and the housing on the very tip, from the side. Just enough to hold a piece of wire that I slide in and hold the button in the "off" position.
I have another button switch from a donor, and sometime later I plan to swap it out, and wire in a toggle switch that I will mount just inside the door jamb.
I suppose if you wanted to overide all the inside lights at once, you could wire in a switch up at the under dash fuse block, and mount it on the dash wherever is convienient.
unoleisu is offline   Reply With Quote
Old 12-08-2010, 08:58 AM   #4
whocares
whocares is on a distinguished road
Default
I'm in sort of the same boat right now. I redid my headliner and didn't do any cutouts for the overhead lights, in front or back. The reason for it is I wanted to put different interior lighting in from another vehicle. I'm not in any hurry to put the lights in so I have been looking at other builds, ebay and checking the J/Y to find the lights I want.
Haven't found much that appeals to me yet, but I want something brighter than the stock lights up there. If you just want to override the hatch switch while your other doors are closed, I would take the hatch switch out and tie into it with a toggle type switch, then put it back in.
Mount your toggle where you want it and use it to interrupt the circuit to the hatch switch. This way, when the hatch is open (front doors closed) you can toggle your interior lights off and on.
I believe all the door/hatch switches operate off being grounded. Like when the door is open, the door switch pops out and grounds the circuit, making the interior lights come on. Someone will correct me if I'm wrong.
__________________
89 BII, a work in progress.
whocares is offline   Reply With Quote
Old 12-08-2010, 10:48 PM   #5
The_Dealer
The_Dealer's Avatar
Year: 1985
Make: Duh!
Model: Bronco II
Default
i would love to have dual ext cab ranger overhead lights that would be schweet, dunno how i'd do it in the cargo area if itd even work
__________________
85 b2/fm146/bw1350
Old 12-09-2010, 10:03 PM   #6
Shran
Shran's Avatar
Shran will become famous soon enough
Default
If I am running around with my doors off in the summer I just pull the dome light fuse. It also disables the ignition buzzer which is nice.
As far as your front headliner hole... I would guess you had a Bronco II overhead console at one time. They have a clock and a weird flip down flashlight looking map light. Snagged one from an '85 a while back but threw it away after storing it for years.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread
1996 Ranger XLT 4x2, 2.3, M5OD
1986 F150 4x2 302/T18
1985 F250 4x4 460/T19
Shran is offline   Reply With Quote
Old 12-11-2010, 06:36 PM   #7
Mudhound
Year: 84 87
Make: Ford
Model: Bronco II Ranger Supercab STX
Engine: 173 and 331 CI
Class: between 4x4 & 4x4 extreme
Used For: wasting materials, time and fuel.
Mudhound is on a distinguished road
Default
For a replacement light for the rear, with a built in switch, go find a 1st gen X in the junkyard. The switch is the EXACT same thing that was used in the BII. I have one with really nice chrome in the caargo area of my 84 BII.
Mudhound is offline   Reply With Quote
Old 12-11-2010, 06:54 PM   #8
The_Dealer
The_Dealer's Avatar
Year: 1985
Make: Duh!
Model: Bronco II
Default
i just pull the bulb when i pull my pins and remove the doors lol..esp since i aint got but one bulb. anyone know if a 95+ overhead console out of an x will work?
__________________
85 b2/fm146/bw1350
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
