| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1988
Make: Ford
Model: Bronco II
Rep Power: 12 ![]() iTrader: (0)
Ive never been able to get the brakes to work right on my b2. You have to pump them about 2 or 3 times to get any pressure. Ive changed the master cyl, both the rear slave cylinders, and the pads front and rear. The only thing left original on it is the booster, lines, and front calipers.
I bled them recently, the fluid looked new and got out all the bubbles, I couldnt get the bleeder screw on the front to come off so i just did the rear, but the fronts always worked fine anyways. I noticed though when I was under the truck and my friend was pump the pedal, there was a splattering sound comming from the driver side rear drum. kind of like when you squeeze a ketchup bottle and only a little comes out. I bled it though and the fluid was clean, no bubbles.
__________________
1988 Bronco II, 2.9L, FM146, 2" rear shackle lift, '98 exploder spring swap, 33" Mud Terrains, Chop top, F-150 coils Last edited by mikhail; 01-24-2008 at 07:48 PM. |
Tweet
#2 |
Year: 89 BII retired
Make: 91 Xplodr Sport
Model: 94 Ranger Xcab 2WD 6" lift
Make sure the rear shoes are adjusted properly. If they're not tight enough you have to pump the shoes out to the drums and the check valves in the master cyl can't keep up. Also some master cyls have an adjustable rod that sometimes has to be readjusted when replaced.
Tweet
#3 |
Logan Andrew Feb 17, 2012
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Getting Passed
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (15)
Bleed those fronts... I had the same problem and it was the fronts... When I plugged the front line at the master cylinder and hit the brakes with the rears only the pedal was SOLID.. This was with the engine running too.
I replaced both front calipers and the problem is gone. Now granted I still don't have a super solid pedal, but it no longer sinks as I am stopping.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop. |
Tweet
#5 |
Year: 1988
Make: Ford
Model: Bronco II
yeah mine does have the 9" drums, I guess thats part of it. Ill bleed the front, but how do I get the rear drums adjusted properly? When I changed the pads I had to twist the adjusting screw in a bit just to fit the drum on.
__________________
1988 Bronco II, 2.9L, FM146, 2" rear shackle lift, '98 exploder spring swap, 33" Mud Terrains, Chop top, F-150 coils |
Tweet
#6 |
Year: 2003
Make: FORD
Model: Ranger-SuperCab
Engine: 4.0 SOHC
Class: 4x4
Used For: Riding mad max style......
Rep Power: 18 ![]() iTrader: (38)
A squishy pedal could be alot of things. But check any rubber lines. If they are weak and expanding, that'll do it. Also when adding brake fluid when bleeding the brakes, make sure to use new brake fluid and keep it sealed. Brake fluid likes to attract water. It will even pull it out of the air (humidity). The water will then evaporate, and puff, air in the lines. You've aleady replaced the MC. So, the only other thing I can think of is like Jspafford said, it could be an internal leak in a front caliper. BTW, brake fluid should be replaced after 2 years of use.
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark. Giddywomp Offroad & Fab
Tweet
#7 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
I bled my front calipers and I still had a mushy pedal.. It would stop decent, but as I was sitting still I could push the pedal to the floor.
When I bled the fronts it didn't help at all.. Everyone seemed to think it was something else... I did what I suggested about plugging each port on the Master Cylinder and found the rear alone had no pedal travel at all, but the front had a ton (to the floor) of pedal travel. When I took the old calipers off, I layed them down and they drained out on the floor. There was some nasty chunks and brown flakes that came out... I thought to myself, that can't be good..
__________________
Tweet
#8 |
Year: 1988
Make: Ford
Model: Bronco II
alright, Ill bleed it again tomorrow after school and see if that helps. it seemed to help a little bit the first time, but not much. I doubt its the lines expanding, ive seen old cars with the original lines have decent brakes.
__________________
Tweet
#9 | |
Year: 1987
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Used For: something to do
Rep Power: 13 ![]() iTrader: (1)
Quote:
__________________
88 Ranger, 2.9L, 4x4, 2nd FM145, 3" PA Body Lift, 3" Suspension Lift, 31x10.5 TSL's, Custom snorkel w/ARB topper, Custom bumper out back, 2x100 Watt Lights, Full 2 1/2" Exhaust w/Cherry bomb, 4.0 Rad, E-fans, Grant Steering Wheel, Herculined interior |
Tweet
#10 |
Junior Member
Year: 2004
Make: Ford
Model: Ranger XLT 4X4
Rep Power: 11 ![]() iTrader: (1)
i have the same problem its not any of that.. the only person that was right was blackbronc.. i had my rear right drum adjusted and the truck stoped on a dime after that, for about 3 days it was great then it whent back to being mushy and pushing its self through stop sighns with my foot to the floor.. when i opend it up i noticed that little arm that tightens the breaks when you spin the little spur wheel was bent, i bent it back and the same problem happend.. its the rears alright but now i need to find out how to replace that adjusting system cause its obviusly FUBAR'ed.
try adjusting the rear breaks, dont do it through the little hole in the drum cause if the spur isent hitting the arm its not going to do anything, take the drum off and see if spinning the spur from the inside is actualy pushing the arm.. i think you have the same problem as me..
__________________
2004 Silver XLT 4X4 4.0L SOHC | 4.10's Open | 5spd Automatic K&N Air Filter | Gibson Muffler 3" PA Body Lift| 265/75R16 BFG A/T's | James Duff Traction Bars
Tweet
#11 |
Year: 1988
Make: Ford
Model: Bronco II
I think I may have fixed it, adjusted the rear brakes and bled them again. It works alot better now, itll lock up the 33s.
__________________
Tweet
#12 |
Junior Member
Year: 2004
Make: Ford
see told ya it would work..
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
