Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4-bangers > 4-Cylinder (2001 & Newer)
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 11-30-2010, 10:36 PM   #1
canoeman
Year: 2004
Make: Ford
canoeman is on a distinguished road
Default 2008 Duratec cold rev
Hi guys,
When my truck is cold, it revs a bit before calming down to about 1500 rpm's, then I shift. Is this normal? Is there a fix?
canoeman is offline   Reply With Quote
Old 12-06-2010, 04:26 AM   #2
JimTheMad
Year: 2009
Make: FORD
Model: Ranger XL 2.3L
JimTheMad is on a distinguished road
Default
Same here, mine start 1500 rpm and drop down slowly, I think it's the automatic choke, so I bet it's no need to worry about it, just let it go.
JimTheMad is offline   Reply With Quote
Old 12-23-2010, 08:59 AM   #3
v8318cid
Year: 2010
Make: Ford
Model: Ranger XLT
Engine: 2.3 litre
Class: 2WD
Used For: Occasional DD
v8318cid is on a distinguished road
Default
I have a 2010 that does that. If the engine is cold, it starts at a higher RPM to both help circulate oil and warm up a little faster. It should only last about 10 seconds or so before slowly declining to 1k. That is considered normal operation as far as I'm aware. I've seen mine go as high as 2k RPMs for a few seconds after initial startup, but usually only if the outside temp is below 50F.
v8318cid is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
