- Jan 20, 2008
well the other day i jacked my truck up to see what the problem with it was and found it to be a stuck rear break..it has been cold here so i don't know if it a factor or not. anyways changed both the rear drum breaks the right one came off easy but the bad one came off hard..changed that and it still was a little tight when i put the thing over it.now the truck actually works better but the brake is still getting hot and rubbing a little bit..is this going to be normal till it breaks in or whats the problem?
