Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 11-26-2010, 07:01 PM   #1
tmkf_patryk
Year: 2003
Make: ford
Model: ranger
tmkf_patryk is on a distinguished road
Default help removing shifter 2003 ford ranger
alright, so I have to replace the slave cylinder, I read up alot and also got a manual for it.
one of the first few steps, remove the shifter from transmission
so, my ranger is 2003, 2wd, and its got plastic molding trim, so I remove the 2 screws with ease and then theres a threaded bolt and a nut
i take the nut off the passenger side onto the drivers side, thread it, then get stuck, try as hard as i can, very very slowly turning but it just keeps getting harder, i take off the nut and see i started damaging it, try a few more times and nothing, there is noway it will thread on, the previous owner must have put lock-tite on it or something, it is physically impossible, only thing i have yet to try is my 4 foot long breaker bar (already thought i broke the shifter twice when the thing just jumped off)
so i need some help or tips what to try next, there must be a way of removing it off the transmission
tmkf_patryk is offline   Reply With Quote
Old 11-26-2010, 08:30 PM   #2
BRUTUS_T_HOG
BRUTUS_T_HOG's Avatar
Year: 89
Make: Ford
Model: Ranger S
Engine: 2.3L
Class: 2WD Street
Used For: everything
BRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of light
Default
i just remove the 3 torx screws down at the base of the shifter and remove the whole thing. only time i bother with what you're doing is to replace shifter bushings
BRUTUS_T_HOG is offline   Reply With Quote
Old 11-26-2010, 08:42 PM   #3
tmkf_patryk
Year: 2003
Make: ford
Model: ranger
Default
its already pitch black outside (i live far north) so i will get at it tomorrow (even though its in the garage)
I will guess that i will have to lift the plastic trim and find the 3 torx there
if there is anything else, let me know, but you helped me so much
thanks! (no thanks to the haynes)
i hope this info is good for the 03 as you got an 89 :P
Old 11-26-2010, 09:52 PM   #4
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Brutus knows what he is talking about man. These transmissions have changed very little in the last 20 years.
First question, are you sure you are turning the nut the right way? If you are sitting in the seat and turning it trying to take it off the front of the shifter, from your perspective it needs to turn to the right. Next, make sure you have the right sized socket or wrench on it. If I recall it's a 17mm.
If all else fails, vice grips.
I will say though, I like Brutus' suggestion. I couldn't figure out how to get the shifter off the first time either and so I just took the Torx screws and the plate off. I find that makes it a lot easier to get the trans to clear the floor pan.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is online now   Reply With Quote
Old 11-27-2010, 09:06 AM   #5
Jspafford
Logan Andrew Feb 17, 2012
Jspafford's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Getting Passed
Jspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of light
Default
This write up is on something else, but it shows a pic and description on how to remove the shifter.
CLICK HERE
Jspafford is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
