Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 11-23-2010, 04:31 PM   #1
peatypaul@yahoo.com
Year: 86
Make: ford
Model: bronco II
peatypaul@yahoo.com is on a distinguished road
Default 86 bronco II rear disc brake problems
I currently have a 86 broncoII with a 302 v8. Im having issues with the braking performance. The brake pedal seems spongy for the majority of the travel then gets stiff with out any extra response to the braking. It does stop but not as fast as i would like. I am not able to make any sudden stops because the the pedal gets hard with no added braking powere no matter how hard i press. I recently installed a 95 explorer 8.8 with disc brakes. I replaced the front and rear calipers and installed a master cylinder from the explorer and an adjustable proportioning valve. I have recently installed a vacuum storage tank to help but not knowing if vacuum is the problem. Im not sure if there is any residual valves affecting the pressure. The only issue with the master cylinder is the resivour makes contact with the booster so i shimmed it out to clear and adjusted the booster pushrod out. any suggestions??
peatypaul@yahoo.com is offline   Reply With Quote
Old 11-23-2010, 04:36 PM   #2
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Un-shim the master cylinder for starters. Your valve may not be adjusted right either, but your master cylinder shim is more than likely causing less than desirable operation.
If it just won't fit on there without the shim, try putting in the 95's booster.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Raj
What you need is cheat codes, motor skills, and a magic genie who grants wishes to little boys who suck at Mario Kart
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 11-23-2010, 04:45 PM   #3
peatypaul@yahoo.com
Year: 86
Make: ford
Model: bronco II
Default
i looked into the explorer booster but it has a larger bolt pattern. I m thinking of getting a master cylinder with the dual resivour to fix the clearance issue but not sure what bore size i need
Old 11-23-2010, 04:49 PM   #4
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Is yours the plastic reservoir or the bale-clip style?
__________________
Old 11-23-2010, 04:53 PM   #5
peatypaul@yahoo.com
Year: 86
Make: ford
Model: bronco II
Default
plastic.
Old 11-23-2010, 04:58 PM   #6
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Try putting your original back in and see. I think the original master will work. Post down in the brakes section, those guys will know for sure.
__________________
Old 11-23-2010, 05:41 PM   #7
peatypaul@yahoo.com
Year: 86
Make: ford
Model: bronco II
Default
When i first did the dixc swap I had the original master cylinder in but it was even worse.
Old 11-23-2010, 06:16 PM   #8
Shran
Shran's Avatar
Shran will become famous soon enough
Default
You don't need the proportioning valve or the vacuum reservoir, for one thing. I have a disc brake 8.8 from a 97 Explorer, a disc brake D44 from a '76 Bronco and my stock master and booster... the brakes work very well.
How sure are you that you got the master cylinder completely bled? I don't think that the shim would cause any issues if you adjusted the pushrod length to compensate for it.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread
1996 Ranger XLT 4x2, 2.3, M5OD
1986 F150 4x2 302/T18
1985 F250 4x4 460/T19
Shran is offline   Reply With Quote
Old 11-23-2010, 06:59 PM   #9
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Quote:
And if you did adjust the pushrod length then it should be ok. I'm sick right now and most of my assumptions are coming from the point of something else not being done right.
__________________
Old 11-23-2010, 10:07 PM   #10
peatypaul@yahoo.com
Year: 86
Make: ford
Model: bronco II
Default
Ive bench bled the master twice and the whole system a few times. still no change. I have the proportioning valve adjusted to operate mainly the front brakes in order to stop
Old 11-23-2010, 11:24 PM   #11
Shran
Shran's Avatar
Default
So were you having problems with the fronts locking up or something?
__________________
Old 11-24-2010, 01:13 PM   #12
peatypaul@yahoo.com
Year: 86
Make: ford
Model: bronco II
Default
No problems with the front. Its mainly the lack of pressure when the pedal is pressed
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
