Go Back   The Ranger Station Forums > Engine & Transmission Forums > Engine Conversions > V-8 Conversion Forums
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 10-23-2010, 04:08 PM   #1
Chevelle Kid
Chevelle Kid's Avatar
Year: 1994 1995
Make: Ford
Model: Fullsize Broncos!
Engine: 5.8
Class: 4x4 Extreme, 4x4 DD
Used For: '94 Bronc on 38s and '95 Bronc stock as a rock DD
Chevelle Kid will become famous soon enough
Default 351w into a Bronco II/ First Gen Ranger
Ok guys, I have a chance at a rebuilt 351w for real cheap. It's from a 1988 Bronco and has the complete wiring harness and computer. I want to pop it into my B2, anybody here done it? I need your experiences from it. I figure I'm going to run a V-8 M50D, and a 1356M t case (can also get for really cheap).
I need just basic info on getting it in and clearing the steering and such.
Thanks
Ben
__________________
1993 Ranger: Single cab, Steppie, 4cyl 5speed.
1995 Ford Bronco 3" BL and 35s, BL coming out soon and a 5.5 Deaver lift going in.
Chevelle Kid is offline   Reply With Quote
Old 10-23-2010, 04:40 PM   #2
snoranger
Boost Junkie
Tetris Champion
snoranger's Avatar
Year: 94,94,95,01
Make: All 10 are Ford
Model: Ex, Cobra, Ex, Ranger
Engine: 4.0,5.0,4BT,4.0
Class: none
Used For: Going places.
snoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond repute
Default
That upper intake is gonna be tall. I dont know if it will fit under the hood.
That trans is kinda weak for a 351w, but it might hold up ok in a light truck like a BII.
A 1356 is going to be a wide t-case, the frame or the case may need to be clearanced to fit.
snoranger is offline   Reply With Quote
Old 10-23-2010, 04:56 PM   #3
eriksf250
Year: 1986
Make: Ford
Model: Ranger
eriksf250 is on a distinguished road
Default
idk if they make them for b2s but you could probably do a body lift for extra clearance for the motor and upper intake
eriksf250 is offline   Reply With Quote
Old 10-23-2010, 09:08 PM   #4
blackwidow67
blackwidow67's Avatar
Year: 1984
Make: Ford
Model: RANGER
Engine: 5.7
Class: 2WD STREET
Used For: BUILDER
blackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to all
Default
Ben, just stick a 396 in it and call it a day 
Anyway, I'd find another t-case. And get a different upper intake for it.
But go for it. I can build the mounts, and you can put it together.
Do it!!!!!!
__________________
********THE BUILD THREAD********* http://www.therangerstation.com/foru...ad.php?t=96344
1984 FORD RANGER. 350 CHEVY SWAP. GONE BUT NEVER FORGOTTEN
1990 RANGER. 302 swap in the works
2001 VeeDub jetta. 2.0 5-speed. The daily driver (for now)
blackwidow67 is offline   Reply With Quote
Old 10-25-2010, 10:04 AM   #5
Chevelle Kid
Year: 1994 1995
Make: Ford
Engine: 5.8
Default
I wanna stick with the stock intake because I wanna run fuel injection, and shelling out $1000 for a Holley kit would bring on the suck...lol
Would there be a different t-case that would bolt up to the fullsize trans?
Ben
__________________
Old 10-25-2010, 11:09 AM   #6
cammeddrz
Premium Member
cammeddrz's Avatar
Year: 1988
Make: Ford/chevy
Model: Bronco II with 3rd gen front clip
Engine: efi 350vortec
Class: 4x4 full-width 3/4 ton axles
cammeddrz is a jewel in the roughcammeddrz is a jewel in the roughcammeddrz is a jewel in the roughcammeddrz is a jewel in the rough
Default
Ben
from what i have heard the intake will not only be tall but will interfere with the heater plenum box, because it is so wide especially if you have a/c
another solution is that i have run tbi's on what were originally mpfi, just take 2 opposing injector wires and run them to each of the injectors, i have several adaptor plates that will stick a gm tbi throttle body to a 4bbl manifold. i'd send you one if you went that route. then all you need to do is make sure the tps has the correct parameters (holley sells different tps's), then you take the nipple of the map sensor and clamp a hose around it that goes to a vacuum line. then if the donor truck ran a maf sensor all you need is a hat for a carb (the top of a gm tbi is 5 1/8" just like a carb) that you can run your intake duct to, spectre makes them for about $60.
last but not least a $35 manual fuel pressure regulator for the throttle body so that you can get the fuel pressure where it needs to be. the fuel curves/injector pulse will be the same because the same computer is running it. you will just have 2 really big injectors running it as opposed to 8 small ones. i have done this on obdII lt1 camaro's so i could put better flowing single plane carb intake manifolds on it. (i used a 1000cfm holley 4bbl throttle boddy though but the principles are the same) and the M.I.L. quit coming on once i adjusted the fuel pressure to where it needed to be.
just a thought.......
also the best plan is to take the entire engine, with the trans still married to the t-case, modify your cross member, and spend the $60 to have your driveshafts modified to fit the fullsize t-case
cammeddrz is offline   Reply With Quote
Old 10-25-2010, 11:31 AM   #7
snoranger
Boost Junkie
Tetris Champion
snoranger's Avatar
Year: 94,94,95,01
Class: none
Default
If you can find a f150 Lightning lower intake (351w), you can bolt an Explorer upper on with no mods. ONLY the Lightning intake or the 95 Cobra R lower will accept the GT40 uppers.
Old 10-25-2010, 10:33 PM   #8
Chevelle Kid
Year: 1994 1995
Make: Ford
Engine: 5.8
Default
Quote:
Hmmmm.....I might go this route.
Cam, I plan on removing the a/c box and adding a modded heat only box to give me more room. This isn't going to be a daily driver so creature comforts can be killed in the name of HP...lol
__________________
Old 10-25-2010, 10:39 PM   #9
snoranger
Boost Junkie
Tetris Champion
snoranger's Avatar
Year: 94,94,95,01
Class: none
Default
IF, you can find a Lightning lower!
Old 10-26-2010, 07:13 AM   #10
Teddyzee
December 2011 STOTM Winner
Teddyzee's Avatar
Year: 1997
Make: Ford
Model: Ranger
Engine: 5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
Class: 2wd
Teddyzee has a spectacular aura aboutTeddyzee has a spectacular aura about
Default
There are affordable aftermarket lower intakes available for the 351.
I've also read accounts of people successfully using the truck intake under a stock RBV hood, but it seems to cause debate.
You should also be able to easily mod the heater box for any clearance issues, too.
__________________
97 Supercab 5.0 H.O. EFI Tri-Y Headers T-5
DJM 5/8 Drop
Cal-Vu mirrors, Shaved badges. Explorer interior
18X9/18X10 Bullitt wheels (275/40, 295/35)
5.0 link
Teddyzee is offline   Reply With Quote
Old 10-26-2010, 05:30 PM   #11
Chevelle Kid
Year: 1994 1995
Make: Ford
Engine: 5.8
Default
I know a few Lightning people..lol
I think I am going to try mocking it up and seeing what fits and what doesn't and going from there. I'd be game for making a custom hood to clear it...lol
Ben
__________________
Old 10-26-2010, 06:07 PM   #12
blackwidow67
Year: 1984
Make: Ford
Model: RANGER
Engine: 5.7
Class: 2WD STREET
Used For: BUILDER
Default
ill weld the hood scoop for ya!
ill be making a cowl induction for mine when i get it going.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
