| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Junior Member
when my truck is cool the oil pump does not seem to get the oil pressure up as quick as it should. some rattle for just a split second until the pressure gets up. Do yall think that a new oil pump would help with the cool starting rattle?
Tweet
#2 |
Year: 1994,2001
Make: Ford Rangers S
Model: Ranger,ext-cab 4-dr
Engine: 4.0 SOHC
Class: 4 x 4
Used For: Daily Drive
Rep Power: 11 ![]() iTrader: (0)
I think there is supposed to be a check valve to keep the oil in the passageway, possible a bit of dirt got in the way of the check-ball. I had the same problem but stepped up my oil changes for a couple of months and it finally went away.
Ron V
Tweet
#3 |
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
Rep Power: 47 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (18)
More often than not a 4.0 with an oil pressure issue has a gummed up pickup.
AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun. |
Tweet
#4 |
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Used For: DD tow boat
Rep Power: 19 ![]() ![]() ![]() ![]() iTrader: (0)
Run 1/2 quart of ATF in it for about 100 miles then change the oil and use a motorcraft filter. See if that helps what kind of filter do you have in it.
__________________
it takes a nickle to go first class when it stops hurting it will feel alot better
Tweet
#5 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L V6
Class: 4x4
Used For: Wrench, Mud, Rinse, Repeat
Rep Power: 6 ![]() iTrader: (0)
I have the same God Awful lower end bearing clatter when I start up after she sits for more than 10 hours...I tried almost 3 different oil filters to no avail. Would Seafoam in the crank case work?
(sorry to jack this thread) but I have been fighting this issue too!
__________________
99 Ex Sport 4.0L OHV 4WD 102K 89 BII 2.9L 5 Spd 4x4 197K 97 Ex 5.0L AWD 250K 94 Ex Sport 4.0L OHV 287K-sold |
Tweet
#6 | |
Junior Member
Quote:
Tweet
#7 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L V6
Class: 4x4
handy,
I replaced the oil sender in my B2 and before that the gauge barely touched (L) for Low. After it was okay and jumped straight to the middle range. I understand that this sender is a on/off switch and doesn't have the capacity to give actual range. That Aside other people here and on other forums with the 4.0L have the same sporadic gauge issue and replacing the sender has almost always fixed it. I also noted that others with this motor Also have the clatter/knocking on cold start up with "good" pressure indicated on the gauge so maybe it incidental to a stopped up pick-up tube?
__________________
Tweet
#8 | |
Junior Member
Quote:
Tweet
#11 |
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 4.0
Class: 2WD
Used For: Daily Driver
Rep Power: 9 ![]() iTrader: (0)
On a 2001 4.0 you can remove the pan without pulling the motor? Everything I've read and heard you have to pull the motor to do that.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
