Signal Light B2600i
Boggin
15+ Year Member
My Left Signal Light On My 93 B2600i Has Been Blinking At About 7000 mp/h, Now My Brother Told Me That It Was Just The Bulb Gone, But I Know Somebody That Had This Trouble And Just Replaced The Fuse, Andbody Got Answers?
Boggin-B:taunt:
i'd check the bulb on the same side, but at the opposite end (front if rear, rear if front).. sometimes that happens when one is out, the other one gets all the power, or the circuit is screwed up somehow otherwise, and it causes the good one to blink double time..
if both bulbs light up, check grounds, replace bulbs, check flasher relay.. if its a dual filament bulb make sure both filaments are good.
Yup, Its The Two Lights, So I'll Check Out What You Said, Thanks
