Go Back   The Ranger Station Forums > Engine & Transmission Forums > Engine Conversions > V-8 Conversion Forums
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 01-19-2008, 01:45 AM   #1
GIJoe4500
Junior Member
Year: 1988
Make: Ford
Model: Ranger
GIJoe4500 is on a distinguished road
Send a message via AIM to GIJoe4500
Default Junkyard Radiator
My internet connection is too crappy for searching. I'm sorry if this question has been asked alot..
If I recal correctly, James Duff carries a v8 swap radiator for RBVs. I also recalling them bein' a tad pricey.
Are there any suitable stock radiators that will be easy to make fit into a Ranger for a v8 swap?
I know it would not be a direct bolt in, like the J.D. radiator would be, I'd just be lookin' for somethin' that would have the inlet/outlet in the correct place, would be around the right size to fit in place of the RBV radiator, and would be adequate cooling for a stock 302/351w.
Thanks,
-Brandon
GIJoe4500 is offline   Reply With Quote
Old 01-19-2008, 09:34 AM   #2
281Ranger
September STOTM Winner
281Ranger's Avatar
Year: 1998
Make: Ford
Model: Ranger
Engine: 4.6 dohc
Class: 2WD Street
Used For: taking up garage space
281Ranger is on a distinguished road
Default
I'm using one for a V8 Explorer. Bolts right into the '98-up, but I'm not sure how it fits in the earlier Rangers.
__________________
1998 Ranger 2WD - 4.6 dohc, Ford prototype intake, custom headers, 4R70W trans, 8.8 rear, 4.10s, trac-lok, aluminum drive shaft, Lakewood traction bars,Mark VIII guages, Explorer buckets, Mark VIII shifter, rear auxiliary fuel tank (no midship), relocated fuel door, fiberglass tonneau cover
http://281ranger.homestead.com
http://www.cardomain.com/ride/2052265
281Ranger is offline   Reply With Quote
Old 01-19-2008, 10:33 AM   #3
GIJoe4500
Junior Member
Year: 1988
Make: Ford
Model: Ranger
Default
Thanks for that info 281Ranger!
Anyone else using somethin' other than a custom, an explorer, or J.D. radiator? Come on v8 people! I know you are out there! haha
Thanks again
-Brandon
Old 01-19-2008, 02:24 PM   #4
GIJoe4500
Junior Member
Year: 1988
Make: Ford
Model: Ranger
Default
I've read a brief amount about using an Explorer radiator out of a automatic 4.0L with A/C. Anyone have anymore information on this? Specifically, if I'll have to run a v-belt or a serpentine water pump?
Old 01-19-2008, 07:02 PM   #5
wickedwindsor
wickedwindsor's Avatar
Year: 1991
Make: Ford
Model: Exploer
Engine: 351
wickedwindsor is on a distinguished road
Default
I've run my original '91 rad with my 351 for a year now. In the hottest days of summer it was fine while driving down the road but on the trail, slow moving, I had to have my electric fan on almost all the time to keep the temp under control. I don't have A/C anymore and the fact you live in Texas, you might decide you need something more substantial. Last week I got myself a brand new aftermarket stock oe rad (2 row). I suspect the old one had lots of 'stuff' in it from over the years.
__________________
'91 Explorer, 351 EFI Windsor swap with 4R70W and Baumann controller. 1356 manual transfer case. 2" body lift, 2" suspension lift. 33" Procomp Mud Terrains.
wickedwindsor is offline   Reply With Quote
Old 01-20-2008, 08:56 AM   #6
projectnitemare
projectnitemare's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
projectnitemare will become famous soon enoughprojectnitemare will become famous soon enough
Default
I use a universal 26x19 aluminum radiator from Jegs. The thing is massive and only $179. It cools my stroker with no problem at all. For a few bucks more you can have a brand new radiator that will easily cool you engine with no problems.
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works
projectnitemare is offline   Reply With Quote
Old 01-20-2008, 09:40 AM   #7
GIJoe4500
Junior Member
Year: 1988
Make: Ford
Model: Ranger
Default
Well, I'm askin' about the explorer radiator, because my cousin says he can get it to me for free. He's a wrecker driver, and his dad is a mechanic.. So they have quite a few vehicles sitting around.
If I HAVE to buy one, it'll be the universal one from Jegs.
So... Anyone know about the Exploder radiator? Specifically which belt set-up I'll need on the motor to make the water flow the right direction.
Thanks again!
-Brandon
Old 01-20-2008, 09:52 AM   #8
Hjcraver
Junior Member
Year: 1993
Make: Ford
Model: Ranger
Hjcraver is on a distinguished road
Default $300 Aluminum Radiator
I thing this radiator on Ebay may work great, but it still cost about $300.00.
Looks like it slides up under the radiator support nicely. I dont know of anyone who has actually bought one.
Item number: 180208264724
85-94 V-8 RANGER ALUMINUM 2 ROWRADIATOR "NEW"
FOR RANGERS OR BRONCO 2 WITH A V8,302,351,460
Hjcraver is offline   Reply With Quote
Old 01-20-2008, 09:58 AM   #9
GIJoe4500
Junior Member
Year: 1988
Make: Ford
Model: Ranger
Default
Thanks Hjcraver. But there is no way I'm gonna spend $300 on a radiator. I just need to know about the Explorer radiator thing right now. I'm gonna keep searchin', but I'm not havin' much luck.
Old 01-20-2008, 02:52 PM   #10
red85
red85's Avatar
Year: 1985
Make: Ford
Model: Ranger
Engine: 306 ci
Class: 2WD Street
Used For: making noise and burning gas
red85 is on a distinguished road
Send a message via MSN to red85
Default
I run a rad out of a 94 Explorer and it cools my V8 just fine. I modified the core support with some stainless I had. It is tucked up under the core support and I run a flex fan with plenty of room to spare.
__________________
Professional Auto Service Tech
1996 Ranger XLT - 3.0 A4LD
1985 Ranger S - 306 ci/C4 (12.96 1/4)gone but not forgotten
1994 Ranger XL - 2.3T/M50D R1 (sadly retired now - Salt cancer got her)
2008 Ranger Sport - 3.0/M5OD R1
Don't ask a question if you don't want to hear the answer!
Putting brains before dollars since 1970
red85 is offline   Reply With Quote
Old 01-20-2008, 03:11 PM   #11
Hjcraver
Junior Member
Year: 1993
Make: Ford
Model: Ranger
Default Queation to Red85
Was the radiator from your 94 Explorer for a 4.0-V6 ?
Was it a 2 or 3 core radiator
Old 01-20-2008, 03:15 PM   #12
GIJoe4500
Junior Member
Year: 1988
Make: Ford
Model: Ranger
Default
The 94 Explorers only came with the 4.0 v6. If it was the automatic trans with A/C its the "super cooling" radiator. My question for you though, red85....is what belt setup do you run? v-belt, or serpentine? That is ALL i really need to know.
Thanks!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
