- Jan 18, 2008
- Age
- 68
- Lincoln,NE
- Automatic
4x4 junkie did it by narrowing the width - aaron mathew of uconn off-road and not all there racing swapped-in the complete full-width dana 44 unit. Jim Oaks did the story on aaron mathew's swap in 2006 for TRS. I want to swap in the complete full-width dana 44 front unit in place of the stock dana35 unit. I wish to run at least 35" tires with 5:13 ring and pinions as I think 5:38 ring and pinions would be to weak. ? Anyway --help. I have purchased a dana 44 from a 1993 full sized Ford Bronco with the abs sensors,swaybar,and stock springs. After a little research I think I will have it rebuilt as I do not have a press,required gauges or ever seen it done. I can't even get the driver side inner u-joint apart to pull the axle through the beam and therefor have the differential free of the whole thing. Obviously then I shall have someone else do the install as the geometry,degree's and travel arc's also are beyond my realm. So--Mr. Oaks,Mr. Mathew,Mr. 4x4junkie and anybody else---how can this be done and who can do this???? Or am I voiding my bladder into the wind while day dreaming. special thank you to --metalmacguyver--Hondafreak08--Bent Bolt--odie1969--and 4x4junkie. this site has no equal. --james oaks--the tech library,forums,resource links and most of all the people who through trial and error have done it and are willing to take the time to resource you make it #1. some of the fab work i have seen leaves me in awe. some of you guys must have had an full floater axle set up with the empty diff case as your rocking crib. i dont even want to think about the mobile. lol thanks again
