rough idle
picarh
10+ Year Member
Hello, I own an 94 Ford Ranger 3.0 v6 4x4 ..
Before i got this problem I change the radiator, so i empty all the system, but it take 3 days before installing the new rad n fill the system,,
After that the idle was rough,,
I change cap and rotor,, spark plug and cable, air/oil filter,ECT sensor
the dealer was check for code, but nothing,, check my O2, masf, iac,,
the only thing was bad compression he said,,And check for new valves,,
I check the compression at another shop and it clean iac sensor:
Cylinder 1-115, 2-100, 3-115, 4-5 and 6-100....
this compression bad enough for my problem ??
If you have any insight or anything, please post it!!!
Hugo :scare:
compression looks alright. is your oil milky or smell like coolant?
Rough Idle---- I got it
Finally I find my trouble, with Hayne's manual..
I clean the (cpk) crankshaft position sensor in the
distributor assembly,,, (called too ''distributor ignition pickup'')
Thank's for help ?? :taunt:
