| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 95'
Make: Ford
Model: Explorer Sport Track 2 door
Engine: 4.0
Class: 4x4 stock
Used For: Everything
Rep Power: 0 ![]() iTrader: (0)
I just bought a 95' explorer 4.0 3 door 5 speed 4x4, I swapped the engine with a 96' 4.0 basically everything was identical in the swap but now it won't start. I changed the top portion of the cam position sensor and the crank sensor.. checked all fuses and replaced the pump. Can someone help me figure this out please! Thanks!
Tweet
#2 |
Year: 2006
Make: Ford
Model: Ranger XLT Extended Cab
Engine: 4.0L
Class: 2WD Country
Used For: Shenanigans
Rep Power: 22 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
check the basics. i know it sounds stupid but things like unplugged computers or even batterys can be overlooked. did it run before the swap? is it getting fuel?
__________________
Camburg BTF mid-travel kit, 64's, 33x12's,E-Fan Conversion, 4.56 8.8, McNeil Glass |
Tweet
#3 |
Year: 95'
Make: Ford
Engine: 4.0
Class: 4x4 stock
It is getting fuel up to the injectors but they won't squirt through. I replaced all the relays (with some I got in a boneyard) Went through a couple of times and double checked plugs, grounds etc.. Basically fuel won't go through the injectors. It seems like it is getting good fuel pressure but idk if maybe the fuel pump could be weak??
Tweet
#4 |
Year: 2002
Make: Ford
Model: F150 XLT
Engine: 5.4l
Class: 2WD
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Is it getting spark? If so, spray some carb cleaner in the intake and see if it starts. Go from there.
__________________
Bert |
Tweet
#5 | ||
Year: 2001
Make: Ford
Model: Ranger XLT
Engine: 4.0
Class: 4x4
Used For: Work & Play
Rep Power: 8 ![]() ![]() iTrader: (0)
Quote:
Quote:
Tweet
#6 |
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 2.9L V6
Class: 2WD
Rep Power: 7 ![]() iTrader: (0)
If none of the injectors are pulsating, look for a common ground maybe. It would be highly unlikely that all of them would fail at once, and these injectors don't rely on fuel pressure to fire.
__________________
1988 Ford Ranger XLT 2.9L 2WD Upgraded interior with Explorer Bucket Seats and Center Console. Currently stock suspension other than upgrade to 235/75R15 wheels/tires. Find us on Facebook |
Tweet
#7 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
Used For: Daily driver. Fishing vehicle. Use from time to time to run down crack heads.
Rep Power: 12 ![]() ![]() ![]() iTrader: (0)
But do they rely on a cam sensor signal for proper timing to pulsate ?
He did change the top half of the cam sensor. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
