| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
Year: 1991/1991/1979
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: everything!
Rep Power: 14 ![]() ![]() ![]() ![]() iTrader: (0)
just thought id say! especially when you dont have every right tool. worked on it for 6 hours and the front still isnt done. got the worst of it out of the way though. at least the rear will be a breeze!
__________________
Koty My SAS, 4.0 swap build: http://therangerstation.com/forums/s...d.php?t=100843 |
Tweet
#2 | ||
Tracked and Locked
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
Rep Power: 94 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (13)
One of the reasons I decided not to lift.
__________________
Project: Hillbilly Deluxe Project: Amazing Grace Project: 12-Volt Sandwich Quote:
Quote:
HELP REPEAL OBAMACARE Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind. |
Tweet
#3 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L V6
Class: 4x4
Used For: Wrench, Mud, Rinse, Repeat
Rep Power: 6 ![]() iTrader: (0)
Koty,
What is the hardest part? I am planning to do mine (my kit has been sitting since June).
__________________
99 Ex Sport 4.0L OHV 4WD 102K 89 BII 2.9L 5 Spd 4x4 197K 97 Ex 5.0L AWD 250K 94 Ex Sport 4.0L OHV 287K-sold |
Tweet
#4 |
Coast Mountain Crawlers
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
5 Years ago, I started my lift after work at 5pm and drove it home drove it home by 11:30pm. It still needed an alignment, but it was all together. With the right tools, and a hoist...its pretty simple actually.
__________________
http://www.coastmountaincrawlers.com 1991 Ranger - one tons, 3 link, air shocks and 40's 1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's. 2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake 1967 Mustang Coupe - 289, c4, pretty much stock |
Tweet
#5 |
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
haha we didnt have ALL the right tools, so there was some impravising. and definately no hoist. but we're getting there
__________________
Tweet
#6 | |
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Quote:
and when putting it back in, the 2 sides of the axles had spread apart alittle- the easiest fix for that was to strap a come-along to each side and just winch the sides together. biggest advice though, is make sure you have AT LEAST one helper, but 2 was ideal for me, cosidering we didnt have a hoist nor all the ideal tools.
__________________
Tweet
#7 |
Year: 1995
Make: Ford
Model: Ranger
Engine: 4.0 V6
Class: 4x4
Used For: Daily driving, Work, Fun
Rep Power: 10 ![]() iTrader: (0)
Rivets kinda suck but a good grinder makes short work of them, that is if u can get the grinder on the rivets. Other than that rust sucks a bit and the nut holding the coil spring if it is rusty it is a mother.
Tweet
#8 | |
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Quote:
and the bolts on the coil springs were kinda rusty, but we used a good cheater pipe on the end of the wrench so it wasnt too bad
__________________
Tweet
#9 |
January 2009 STOTM Winner
Year: 1995
1999
Make: Ford
Model: Ranger 4x4
Engine: 4.0. 4.0 Supercharged
Class: 4x4 offroad, 4x4 dd
Used For: work, dd, trail, race
Rep Power: 15 ![]() iTrader: (21)
i usually disassemble the front axle and put the beams up separately. Much easier that way and you get the regrease the bearings and everything since your in their.
__________________
95 4x4 35 bfg 15x10 soft 8s custom front/rear bumpers,xrc8 winch explorer disc 4.56ls axle locked d44 EB axle sas power leather explorer seats, OHC, m1354, 04 SOHC 4.0 swap 00 4 door cab swap 99 4x4 avm upgrade, 32 bfg on dc1s, ohc, sport trac leather seats/console swapped to manual trans |
Tweet
#10 |
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Of course it's a pain, if it wasn't, everyone would do it!
Good luck on yours Richard
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein |
Tweet
#11 |
Year: many
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: DD/ offroad beater
Rep Power: 16 ![]() ![]() iTrader: (3)
And this coming from someone that has installed at least a half dozen TTB lifts, and removed and disassembled countless others. It definately is easier to work with beam by beam, you would think it would be easier in one piece but you will spend more time fighting with it.
__________________
86 Ranger, 4.0, M5OD, BW1354M, D35 L/S, 8.8, Detroit, 4.56's, York OBA, 200 amp alt, Dual Batteries, 33x12.50x15 Procomps, Skyjacker 6" class II, Belltech 6400's, XRC8, 63" Chebbies, 339k miles Last edited by holyford86; 09-26-2010 at 10:45 AM. |
Tweet
#12 |
Year: 1995
Make: Ford
Model: Ranger Splash
Engine: 3.0
Class: 4x4 6'' Lift
Rep Power: 11 ![]() iTrader: (2)
I did alot of mine myself with the odd helping hand here and there and the worst thing is the stupid rivtes, i did major grinding on all of them up front plus replace all the hangers, other then that i did alot of other work, like all new brakes lines and ETC i took about 2 weeks doing it, working here and there, and taking my time, running back and forth to get parts and wating on others... but wasnt all that bad... having all the parts ready and an extra hand it could be done in a day,
__________________
1995 Ford Ranger Splash
6'' Rough Country Lift-33'' BFG M/T's On Procomp 1089 Wheels-Super Runner Steering Kit-2004 TRX480R-12.5.1 Comp-Rage Ported Head-Bored 42.5 FCR-Rossier Exhaust-Stage 2 Hot Cam |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
