| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| 4X4 Suspensions For stock & off-road suspensions using stock & aftermarket parts (IE suspension kits). Forum sponsored by RCI Metalworks |
Thread Tools | Display Modes |
#1 |
Year: 1995
Make: Ranger HD
Model: XL
Engine: 2.3 I4
Class: 4x4
Used For: Scrap Metal, Off Road, Work
Rep Power: 0 ![]() iTrader: (0)
Im doing the steel washer coil spring lift on my ranger. When i unhooked the shock and sway bar, the i beam refuses to come down and the coil spring will not come undone, i followed the instructions in the tech library, but is there something missing to bring the suspension down. Thanks for the help in advance!
__________________
Proud to be a U.S. Navy Sailor. Being thousands of miles away form your Ranger sucks. 1995 Ranger XL, 2.3 I4, 160k, 4x4 1992 F-150 XLT, 5.0, 236k and counting 1987 Mustang, 5.0, 92k. |
Tweet
#2 |
Coast Mountain Crawlers
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
You removed the lower coil retainer nut right?
__________________
http://www.coastmountaincrawlers.com 1991 Ranger - one tons, 3 link, air shocks and 40's 1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's. 2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake 1967 Mustang Coupe - 289, c4, pretty much stock |
Tweet
#3 |
Year: 1995
Make: Ranger HD
Model: XL
Engine: 2.3 I4
Class: 4x4
yes but the coil wont come off the top of the mounting its still attached at the top
__________________
Tweet
#4 |
Make: Ford
Class: 4x4
You twist it to 'unlock' it from the tabs in the coil bucket.
__________________
Tweet
#6 |
Year: 1995
Make: Ford
Model: Ranger Splash
Engine: 4.0 V6
Class: 4x4 Off-Road
Rep Power: 13 ![]() iTrader: (4)
Don't pry it...those tabs are there to keep the coil secured. You don't want them bent. Twist it out as mentioned above.
You can use your foot and put pressure on the hubs to help the axle droop some.
__________________
95 Ranger Splash, 4.0, M5OD-R1, BW1354M, D35, Exploder 8.8 31spl 4.88, No-Slip, SJ Class II 8" Lift, 3" BL, F250 Shock Towers, Bilsteins, 1pc DS, 35" BFG M/T KM2s on 15x10s... 95 Explorer, 01 ST, 03 Explorer 4.6 2V V8, 08 ST Adrenalin 4.6 3V V8 |
Tweet
#7 |
Year: 1995
Make: Ranger HD
Model: XL
Engine: 2.3 I4
Class: 4x4
Thank you for your help gentlemen i truly appreciate it!
__________________
Tweet
#8 |
December 2011 OTOTM Winner
Year: 1996
Make: Ford
Model: Ranger SC 4X4
Engine: 4.0
Class: 4x4 Extreme
Used For: everything
Rep Power: 15 ![]() ![]() iTrader: (2)
we just wanna see pics of the completed truck
l8r, John
__________________
SAS with leaves, KP HP D60 front, D60 FF rear, 4.88's, 39.5x13.50x17" Bias Iroks, 17" Allied Beadlocks, winch, and a few dents and scratches...... |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
