| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 2001
Make: Ford
Model: Ranger XLT Offroad
2001- t bar crank 33s body lift explorer spring swap
Engine: 4.0 SOHC
Class: 4x4
Used For: daily driver light trail/mud riding
Rep Power: 12 ![]() iTrader: (0)
my 2001 sohc is popping a PO113 code for Intake Air Temp Circuit High...whats this mean parts wise and how do i fix it cause its causing my engine to idle higher than normal on startup and when its not in a drive gear
__________________
Theres just enough room in a Ranger for us, the girls, the dog and a case of Bud Light.... http://www.myspace.com/littlesoldierboy http://www.facebook.com/?ref=home#!/mwooditch let me know your TRS if you add me |
Tweet
#2 |
Year: 1995
Make: Ford
Model: Ranger Splash
Engine: 4.0 V6
Class: 4x4 Off-Road
Rep Power: 13 ![]() iTrader: (4)
If you have six wires running to the MAF sensor, it is built in it. If only four, you have a separate IAT sensor just downstream of the MAF.
Check for loose grounds, then replace as necessary.
__________________
95 Ranger Splash, 4.0, M5OD-R1, BW1354M, D35, Exploder 8.8 31spl 4.88, No-Slip, SJ Class II 8" Lift, 3" BL, F250 Shock Towers, Bilsteins, 1pc DS, 35" BFG M/T KM2s on 15x10s... 95 Explorer, 01 ST, 03 Explorer 4.6 2V V8, 08 ST Adrenalin 4.6 3V V8 |
Tweet
#3 |
Year: 2001
Make: Ford
Engine: 4.0 SOHC
Class: 4x4
ive got 6 so do i need to replace the MAF?
__________________
Tweet
#4 |
Year: 1995
Make: Ford
Engine: 4.0 V6
Class: 4x4 Off-Road
Most likely....the best way to confirm this is to hook up a scanner to your truck and watch the live data as your truck runs. Your intake temps shouldnt be too much higher than ambient temp.
__________________
Tweet
#6 |
Year: 2001
Make: Ford
Engine: 4.0 SOHC
Class: 4x4
on a cold engine well fairly cold i drove 4 miles to the orilley my buddy works at. it registered 147 degrees for the intake air temp. ill try plugging in a new mass air flow and see what that does. i sprayed cleaner in there but didnt take it out of the intake tube. should i try cleaning it again out of the housing?
__________________
Tweet
#7 |
Year: 1995
Make: Ford
Engine: 4.0 V6
Class: 4x4 Off-Road
Obviously, cleaning the MAF would be the first thing to try. The best way is to remove it, as it cleans it more thorough.
If your truck was in fact cold and not up to full operating temp your incoming air shouldn't be 150 degrees unless of course its 90+ degrees ambient temp. If you have access to another MAF you can swap them out and see if it changes. Let us know the results.
__________________
Tweet
#8 |
Year: 2001
Make: Ford
Engine: 4.0 SOHC
Class: 4x4
best friend works at the parts store so he'll just pull one off the shelf test it on my truck and throw it back in the box if it dont work. im gonna try that first and see what happens
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
