- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
last weekend I was working on a '94 ranger with a M5OD, the clutch was toast, and the pedal felt more like a brake pedal than a clutch pedal, so we replaced the slave cylinder while we were in there, after reassembly and some gravity bleeding, it was tested and had nearly no pedal feel at all, super soft and wouldn't disengage fully, proceded to bleed the normal way and more gravity bleeding, so we got a new master cylinder, bench bled it and reassembled, same thing. by this time the whole weekend had gone by (well, all of the useful daylight part), and both of us were sore, tired and super frustrated (especially that getting the tranny in which should be the hard part was the easy part...)
the owner of the truck went to the clutch doctor or some other shop and they said the pilot bearing could be the problem, right now I'm thinking that's not it since the tranny went in on the first try, the bearing was still greasy, and it wasn't acting up before.
during the clutch replacement, the flywheel looked like new, no ridge what so ever so it wasn't replaced, pilot bearing wasn't either since it seemed in good shape, every other clutch component other than the hard line was replaced, including friction disk, pressure plate, throw out bearing, slave cylinder, and master cylinder
any ideas or assistance would be greatly appreciated!!!!!!!!!
also, anyone know the diameter of the pilot shaft on a M5OD for a 2.3L? in the off chance it does need replaced, I would like to be prepared with a dowl or piece of machined aluminum (have a lathe and plenty of round stock to turn down) to hydraulically remove it
