Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Brakes
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 01-16-2008, 12:06 AM   #1
scottp
scottp is on a distinguished road
Default Brake Vibrations
I have a 2001 Ranger. A couple of years ago I noticed that the steering wheel was vibrating a lot when I applied the brakes. I had the brakes checked out, the wheel cylinders in the rear brakes was leaking causing the rear brakes to essentially never work, all stopping was done only with the front brakes. The rotors were warped on the front brakes. I had the rotors turned and new brake pads on the front brakes and the wheel cylinders on the rear brakes were replaced.
Now I'm noticing a similar problem again. The guy told me when he turned the brake rotors that they were at spec and couldn't be smoothed out any more. I'm not sure how many miles I have put on the truck since I had this brake work done, maybe 20K. I suppose the rotors are warped again and need to be replaced. Do you think the rotors just got warped on their own, or do you think the rear brakes may not be working properly again causing the front brakes to do all the work again? Or do you think 20K miles on thin rotors is about right? Or could the vibrations be caused by something else?
On a somewhat related note, do you have any estimate as to what it would cost to have the rotors replaced, ballpark figure?
Thanks
scottp is offline   Reply With Quote
Old 01-16-2008, 02:09 AM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
When you machine rotors down to minimum spec they are more likely to warp as they are thinner. With how cheap rotors are I just replace them instead of machining.
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is online now   Reply With Quote
Old 01-16-2008, 07:37 AM   #3
dirtsquirt
dirtsquirt's Avatar
Year: 1987 and 2005
Make: ford And jeep
Model: Bronco 2 xlt TJ unlimited Rubicon
Engine: 2.9 And 4.0
Class: 4X4
Used For: Daily driver, off road
dirtsquirt is on a distinguished road
Default
Quote:
Just checked out the coast mountian link in your message ( man i miss the mountian's
__________________
DirtSquirt!
Paved road's !! Another government waste of money!!
http://www.cardomain.com/ride/2961522
dirtsquirt is offline   Reply With Quote
Old 01-16-2008, 04:20 PM   #4
Sasquatch_Ryda
Make: Ford
Class: 4x4
Default
Quote:
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
