rear tail,brake,turn signal and liscense lamp??
rangerbronco288
15+ Year Member
Westland Michigan
Ok so rear of my truck has no brake lights or turn signals running lights or liscense plate lights. The only light on the rear of the truck that work are the reverse lights. Anyone else have any kind of a similar problem????
Sounds like it might be a problem with the rear lighting harness. Start at the passenger side tail light and follow the harness over to the driver side, then up the frame rail to the front. You're looking to see if there's any damaged harness or connectors. In a lot of these cases a previous owner wired in a trailer harness and did a hack job, so look closely at the harness behind the rear bumper.
