| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| 4X4 Suspensions For stock & off-road suspensions using stock & aftermarket parts (IE suspension kits). Forum sponsored by RCI Metalworks |
Thread Tools | Display Modes |
#1 |
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 4.0
Class: 4x4
Rep Power: 0 ![]() iTrader: (0)
My fron tires are leaning in and wearing on inside of tires...how do i adjust camber bolts...i need directions fast lol i dunno too much about it so you will have to break the directions down so i can understand lol
Tweet
#2 |
Year: 97, 97, 91, 69
Make: ford
Model: ranger, ranger, ranger, mustang
Engine: 4.0, 2.3, 4.0, 5.8
Class: 4x4, 2wd, 4x4, 2wd
Used For: weekend beast, DD, need to sell, first car
Rep Power: 13 ![]() iTrader: (1)
the camber is adjusted at the upper ball joint. there should be a pinch bolt that holds the cam from moving. so you need a 15mm socket to loosen the pinch bolt and a ..... i think its a 38mm socket or 39mm socket barely fits the camber cam. then you have to retorque the pinch bold to 80 ft/lbs... well thats spec but just make sure its snug. now when you change your camber it messes up your toe. so you have to reset the toe after you change the camber.
__________________
97 ranger 4.0, m5od-hd, 1354m, 4.56, detroit locker front and rear, explorer 8.8, 31s 97 ranger 2.3, manual 2wd 91 ranger 4.0, a4ld, 1354e, 6" lift, 35s 69 Mustang conv, 351c, c6, 9" |
Tweet
#4 |
WRENCH WERKS
Year: 1994
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 2WD OFF ROAD
Used For: EVERYTHING A RANGER CAN DO, AND LOTS OF THINGS IT SHOULDN'T
Rep Power: 18 ![]() ![]() iTrader: (0)
unless you already have adjustable camber bushings then you will need to take it to an alignment shop as richlands55 said. your springs have likely settled and you could possibly have worn front end parts which will cause the tire lean and wear that you are describing. i installed 2" leveling coils on my 94 and after having them on for a year they have settled and now my tires are leaning in at the tops. i plan to get a daystar 2" spacer kit and then have it aligned after wards to regain my levelness and increase my tires life.
__________________
1994 Ranger 4X2 Off Road, Built Not Bought! http://www.therangerstation.com/foru...ad.php?t=37621 |
Tweet
#5 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Daily Driver
Rep Power: 8 ![]() iTrader: (0)
I second that. More than likely, even if the factory bushings are adjustable, they are probably turned to max. camber or close to it anyway. You probably won't gain much, if any. Not to mention you'll be screwing up your caster and toe-in at the same time. Having your toe-in screwed up will wear the tires faster than the camber problem you have now.
Tweet
#6 | ||
Tracked and Locked
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (13)
Factory bushings are round with a centered hole. No adjustment.
Even if you have the adjustables in already you still need to take it to an alignment shop and get it done there. Without the alignment machine to tell you, or the proper training, you won't know if you are moving in the right direction or not. You also won't know how far to go, when to stop, or anything like that. Alignment is a thing of finesse, fractions of an inch make a huge difference in you angles.
__________________
Project: Hillbilly Deluxe Project: Amazing Grace Project: 12-Volt Sandwich Quote:
Quote:
HELP REPEAL OBAMACARE Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind. |
Tweet
#7 |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Not always (infact rarely).
However I agree, they're probably already set for close to whatever maximum they will allow. Messing around with them (especially without making sure there isn't some other issue with your frontend) could be opening a huge can of worms.
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
