| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Mazda B-Series Specific Addressing issues specific to the Mazda B-Series trucks |
Thread Tools | Display Modes |
#1 |
Junior Member
So I just noticed that when truck is idling in neutral, the idle surges from 10-15 seconds at 600 rpm to 900 rpm for 5 seconds, then repeats at a fairly regular interval.
I do not notice any surging once moving. Plugs, plug wires, and pcv valve were changed about 1500 miles ago-so fairly fresh. Any thoughts on steps to start troubleshooting? TIA. -Scott Last edited by Research Rat; 09-06-2010 at 01:50 PM. |
Tweet
#2 | ||
Premium Member
Year: 1995
Make: Ford
Model: Ranger
Engine: 2.3
Class: 2WD
Used For: Warding off gold diggers
Rep Power: 48 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Clean out your IAC valve
__________________
My EX250 build thread Quote:
Quote:
Tweet
#4 | |
Year: 1999
Make: Ford
Model: Regular Cab, Styleside,
M5OD,
3.73 open 7.5 axle,
RABS,
139k(3/08/2012),
no A/C,
Engine: 2.5(5w30)
Class: 2WD
Used For: As a Turd Vehicle
Rep Power: 12 ![]() iTrader: (0)
Quote:
*make sure you air intake is clear and the air filter is good Last edited by modelageek; 09-08-2010 at 11:14 AM. Reason: * |
Tweet
#5 |
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Used For: DD tow boat
Rep Power: 19 ![]() ![]() ![]() ![]() iTrader: (0)
If you clean the maf disconnect the battery for 1/2 hour and then run it for about 20 mins to reset the computer to new values.
__________________
it takes a nickle to go first class when it stops hurting it will feel alot better
Tweet
#6 | |
Junior Member
Hey Modelageek,
Thanks for pointing out the site, I have a good idea of the part now. You posted some other info that I'm not familar with. What is the cel? I have not checked for codes since I don't have a code reader-do you know if you can you borrow one from an autozone or similar? I replaced the air cleaner with the oil change which was just a few hundred miles ago-so this should be good. -Scott Quote:
Tweet
#7 |
July 2011 OTOTM Winner
Year: 1989, 1991
Make: Ford
Model: Bronco II XLT, Ranger XLT
Engine: 4.0, 2.3
Class: 4x4, 2WD
Used For: the rippin and the tearin
Rep Power: 22 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (5)
IAC or vacuum leak are your most common problems.
x2 definitely do this. And make sure a/c and defrost are off.
__________________
89 Bronco II XLT: 4.0, A4LD/5R55E, 1354 Doubler, 35" Baja Claws, XJ coils, FW HP44, Tru-Trac, Spooled FW 8.8 Disc Brake, 4.56s, OBA 91 Ranger XLT: 2.3, M5OD, Dream Beams, 31 spline 8.8, Rear Discs, Limited Slip, 3.73s 04 Focus ZX3: 5.0, T5, 4 lug 7.5, Rear Discs, 3.73s 12 Focus SE: Sport & Winter Package, ST Front End |
Tweet
#8 | ||
Premium Member
Year: 1995
Make: Ford
Model: Ranger
Engine: 2.3
Class: 2WD
Looks like everybody else beat me to it. lol
Anyway the CEL is check engine light. Autozone will pull the codes for free.
__________________
Quote:
Tweet
#10 |
Junior Member
I found the culprit: the defroster was on.
A friend with the same truck pointed it out to me the other day, with the defroster on, the idle surges (ac pump on?) like clockwork mentioned above. With defroster off, idles as should. I'm assuming this is normal? -Scott |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
