No Spark to ground side of coil
richardl0565
15+ Year Member
On this 86 B2 2.9 I have replaced the distributor with pickup module, TFI Module, coil with new units. Still have no spark. I did a spark test with a spark plug attached to the main coil wire that leads to the distributer cap and showed no spark or voltage present at all. I checked the hot lead to the coil (red wire) and im showing matching battery voltage there but there is no ground showing from the TFI module to the coil. Before replacing the above it started and stalled after warm up then conked out. This led me to believe the TFI module had become defective as this is 1 of its symptoms when it croaks. I still dont get ground from the TFI to the coil. Tomorrow I am going to replace the ground wire from the TFI to the coil and see if this resolves the problem. Any suggestions as to what this might be if this trial does not work? Please help.:bad:
I checked the hot lead to the coil (red wire) and im showing matching battery voltage there but there is no ground voltage going from the coil out on the TFI module to the coil.
There is no such thing as ground voltage. If it is ground, there is no voltage. There is a pick up sensor inside the distributor? This is what tells the TFI to fire the coil. This sensor goes bad as often as the TFI. shady
Ground Voltage
Sorry I should have stated no ground signal from the TFI module to the ignition coil. Plus the distributer is new w/new pickup module, plus a new TFI module I already mentioned.
Resolved my problem
I checked as I stated and found there was no ground signal running from the TFI module to the ignition coil. This is the green/yellow wire hooked up to the - side of the coil itself. I replaced that wire and I achieved the needed spark from the coil wire using a tester. The spark is bright blue. I resolved my own problem. I hooked up the wire to the cap and the engine started, with timing adjustment to 10 degrees btdc by disconecting the spout connector it adjusted perfectly. shut her down and reinstalled the SPOUT connector. she starts and runs like a dream.
Resolved my problem
I checked as I stated and found there was no ground signal running from the TFI module to the ignition coil. This is the green/yellow wire hooked up to the - side of the coil itself. I replaced that wire and I achieved the needed spark from the coil wire using a tester. The spark is bright blue. I resolved my own problem. I hooked up the wire to the cap and the engine started, with timing adjustment to 10 degrees btdc by disconecting the spout connector it adjusted perfectly. shut her down and reinstalled the SPOUT connector. she starts and runs like a dream.:yahoo:
Good diagnosis. Broken/intermittent wires and bad connections can be a bear. Thanks for reporting back. shady
X2 and thanks for posting back with what your fix is!
