| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8 |
Thread Tools | Display Modes |
#1 |
December 2011 OTOTM Winner
Year: 1996
Make: Ford
Model: Ranger SC 4X4
Engine: 4.0
Class: 4x4 Extreme
Used For: everything
Rep Power: 15 ![]() ![]() iTrader: (2)
wanting to know all about the Stage 8 spindle lock kit for the Dana 35....
how does it differ from the 44 kit?? l8r, John
__________________
SAS with leaves, KP HP D60 front, D60 FF rear, 4.88's, 39.5x13.50x17" Bias Iroks, 17" Allied Beadlocks, winch, and a few dents and scratches...... |
Tweet
#2 | |
Year: 1994
Make: ford
Model: ranger
Engine: 4.0
Class: 4x4
Used For: dd and playin
Rep Power: 10 ![]() ![]() iTrader: (10)
well i called them a few months ago bout this same question or similar and the answer i got was the stage 8 that they offer is too large to fit inside a ranger hub and will only work on a jeep d35. so i just went and bought a new set of manual lock nuts as mine where worn out from a previous owner not owning the proper nut socket and used a hammer and chisel to tighten and loosen them. if u keep a check on them i check mine every month or two for proper torque u should b just fine.
__________________
did you get stuck in your yard with that 2wd? quoted from ozziemo27 Quote:
Tweet
#3 |
Coast Mountain Crawlers
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Yup, as stated they won't fit.
__________________
http://www.coastmountaincrawlers.com 1991 Ranger - one tons, 3 link, air shocks and 40's 1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's. 2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake 1967 Mustang Coupe - 289, c4, pretty much stock |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
