| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here. |
Thread Tools | Display Modes |
#1 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.9l V6
Class: 4x4
Used For: Offroad
Rep Power: 10 ![]() iTrader: (5)
hey guys where should i run the power wire for the background light in my oil pressure and temp gauges that i just installed? i want them to light up when i turn the headlights on. is there any easier way the pulling the headlight switch out and splicing into it? if not what color wire do i need to splice into on the back of the switch? the truck is an 88'. thanks
__________________
88' Ranger:5-speed, 6" lift, Detroit locked D35, Locked 31 Spline 8.8, 35's, 5.13 Gears... .. |
Tweet
#2 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.9l V6
Class: 4x4
Used For: Offroad
anyone??
__________________
Tweet
#4 |
Year: 2006, 1994
Make: Ford
Model: Ranger, Explorer
Engine: 4.0 SOHC, 4.0 OHV
Class: 4x4
Used For: Pavement Poundin'
Rep Power: 21 ![]() ![]() ![]() ![]() iTrader: (0)
You can tap into one of the wires that go to the stereo. This is especially easy if you have an aftermarket unit installed. It should be an orange wire.
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 45k miles 1994 Ford Explorer Sport 2-dr 4x4, 178k miles |
Tweet
#5 | |
\----===FoMoCo===----/
Year: 1997 / 1989
Make: Ford
Model: F150 XLT / Mustang GT
Engine: 4.6 Triton / 5.0
Class: 4X4 / Hot Rod
Used For: Everything / The war on imports
Rep Power: 62 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
Quote:
Somebody get this man some rep power! |
Tweet
#6 | |
Year: 2006, 1994
Make: Ford
Class: 4x4
Quote:
When I installed my aftermarket stereo, I tapped into the illumination wire and the switched power wire and left the wires hanging behind the dash, just in case I ever wanted to install some gauges. Now I won't have to remove the stereo if I want gauges, the wires are already there, ready to go!
__________________
Tweet
#7 |
Year: 1989 Ranger
Engine: 2.9
Class: 2wd
Used For: Everyday transportation
Rep Power: 0 ![]() iTrader: (0)
I have an 89 Ranger and there is a dashlamp wire to the ashtray connector. I used it to connect a light in my aftermarket floor shifter, This should work fine and is easy to get to.
Tweet
#8 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.9l V6
Class: 4x4
Used For: Offroad
ran it to the illumination wire behind the headunit..works fine and dims..thanks alot guys!
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
