Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 08-24-2010, 07:11 PM   #1
RayRayBaby1990
RayRayBaby1990 is on a distinguished road
Default 4.0 swap q's
Ok me and my wife are tackling the infamous 4.0 swap. We got a 92 4.0 out of a Explorer. I have been studying all the info I can find online about the swap. From what I have gathered If I use a 1990-1992 Ranger Harness I won't have to splice anything it's just plug and play?? And for the 4 wires you would have to splice for the heater controls all you have to do is swap the blower resistor and it will plug right in ?? I'm trying to do this swap with as little wiring as possible. Please help !!! I'm currently trying to locate a harness and ECU, which for some reason is rather hard around here (delaware). Right now I'm tearing into the motor, I'm going to do a compete gasket kit and paint the motor, and was going to play with wiring it in the mean while. If anyone can help me I would appriciate it.
RayRayBaby1990 is offline   Reply With Quote
Old 08-24-2010, 07:20 PM   #2
kunar
Odd One
kunar's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
kunar is a glorious beacon of lightkunar is a glorious beacon of lightkunar is a glorious beacon of lightkunar is a glorious beacon of lightkunar is a glorious beacon of light
Default
whats the vehicle you're working on?
__________________
1987 Ranger Supercab STX, 4.0/M5OD/BW1350 4.10LS, 2" Lift, Cut Fenders, 33's
1987 Thunderbird Turbo Coupe (Mostly stock, for now...)
1991 Escort GT (Daily Driver)
Past: 87 Supercab, 87 Longbed, 89 Shortbed, 96 Explorer Sport
kunar is online now   Reply With Quote
Old 08-24-2010, 07:57 PM   #3
country0001
country0001's Avatar
Year: 1990,92
Make: Ford,Ford
Model: B2,F150
Engine: 4.0,5.0
Class: 4x4, 4x4
Used For: tearin up the gravel roads
country0001 has a spectacular aura aboutcountry0001 has a spectacular aura about
Default
The tech library is very detailed about this. Thats the main thing I used on my swap.
__________________
Quote:
Originally Posted by MountainMike View Post
"Quietly the BroncII waits for the prey to walk past, the Ranger will have to wait its turn."
BUILD THREAD http://www.therangerstation.com/foru....php?p=767381#
country0001 is offline   Reply With Quote
Old 08-24-2010, 10:39 PM   #4
RayRayBaby1990
Default
I have read on the tech section but im double checking myself....its a 1990 bronco ll. So do i have it right in my first post?? Cause i know there are variations....but if i use a 1990 or 1991 ranger harness than it should plug right into the bwp right?? And than i could wire my lights into the new bwp?? Sorry read so much info today im starting to oget overwhelmed. Sorry for being such a noob but i really want gto get this right the first time.
Old 08-25-2010, 10:02 AM   #5
country0001
Year: 1990,92
Make: Ford,Ford
Model: B2,F150
Engine: 4.0,5.0
Class: 4x4, 4x4
Default
Apparently they changed the harness every year. Mine came from a 94 ranger. I took the entire harness,and the only thing that was spliced was the taillight harness. Every swap is different.
I still have some issues with blinkers, and stuff, some were there when I got the truck and just compounded as I added the new stuff.
Looking back, it wasn;t that bad. During the swap, I cussed a lot. Its recommended that you have the donor vehicle there, while ur doing the swap, so u can go back and forth. You will do a lot of that. Also its handy when u forgot something that u need.
Accelerator cables are diff, does ur donor vehicle have elec shift 4wd, what about power windows, if ur going that route. Don't forget about the inertia switch.
Plus a million other things.
Its well worth the time and effort. I will be doing this in my other B2 as soon as I can find and afford a suitable donor vehicle.
__________________
Old 08-25-2010, 10:05 AM   #6
country0001
Year: 1990,92
Make: Ford,Ford
Model: B2,F150
Engine: 4.0,5.0
Class: 4x4, 4x4
Default
Get a haynes or chiltons manual too. They come in real handy. One for the B2/ranger will work as long as u stay below 92. If u get an explorer harness, u will need an explorer manual.
__________________
Old 08-25-2010, 12:31 PM   #7
multiranger
Praise the Lowerd!
multiranger's Avatar
Year: 1990
Make: Ford
Model: Ranger
Engine: 4.0
Class: 2WD Street
Used For: Weekend Toy
multiranger has a spectacular aura aboutmultiranger has a spectacular aura about
Default
Quote:
You need a 92 wiring harness.. the dash wiring is the only wiring that is plug and play... Even the wiring for the light switch when you open the doors will need to be changed... So unless the harness is with the dash... use a 92 harness.. I have done two 4.0 swaps and this applied for both...
__________________
89,90,92 Rangers combined to build one. 4.0L... Headman headers, polished Intake,Screamin Demon Coil, 3/4 suspension drop ,K&N Air filter, Hurst short throw shifter..17X10.5 & 17X9 Cobra R wheels. Check out my build thread http://www.therangerstation.com/forums/showthread.php?t=64164
multiranger is offline   Reply With Quote
Old 08-26-2010, 08:50 PM   #8
RayRayBaby1990
Default
Ok well i guess i fudged up....i grabbed a harness out of a 1994 xploder....though it didnt have the cam syncro. I plugged it in tonight....im going to need to splice the tails.....i have interior power....aside from power windows and locks.....and that was just off plugging it in.....but my switched power isnt working. Also my instrument lights are staying on constant. Going to get the wiring diagrams tomorrow. I just thought i would try plugging it in and see what happened....just playin around right now while the motor is being overhauled.....didnt want to throw junk in it....and than pull it 2 months from now
Old 08-26-2010, 08:55 PM   #9
kunar
Odd One
kunar's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
2nd gen truck, 2nd gen engine. you are already set up for the easiest 4.0 swap possible. use a 90-92 ranger wiring harness and it will be plug and play.
if you cant find that harness, it can still be done. it wont be nearly as easy though....
__________________
Old 08-26-2010, 09:01 PM   #10
RayRayBaby1990
Default
I was looking for a 90~92. Harness from a ranger......seems to be impossible around here though.....of course i only paid 30 for this one and the ecu......so maybe ill look around some more. Im in delaware....so if i have to drive to md or va to get one it will still be ok.....if anyone on here is from around my area and knows where there is one let me know ill go get it im wanting this swap to go as easy as possible. Its the wifes truck and she is getting antsy to drive her baby again
Old 08-26-2010, 09:19 PM   #11
kunar
Odd One
kunar's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
you'll want to use the computer that came with the engine. i think after 92, they did the fuel injection differently.
__________________
Old 08-26-2010, 09:21 PM   #12
RayRayBaby1990
Default
ECU didn't come with engine....did I screw up all the way around ??
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
