| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 | |
Year: first gens
Make: Ford right?
Model: Bronco2 and Ranger
Engine: anything but stock
Class: 4x4 Extreme
Rep Power: 12 ![]() iTrader: (0)
I need some insight on a frame off restoration/revamp. I've had my 87 bronco2 since 97, I cant part with it she's my baby. I've been driving the wife's 88 standard cab shortbox as my daily driver for almost a year now. I like the standard cab but can't stand that its a 4cyl 2wd. What I want to do is put a standard cab on my B2 chassis with a short flat bed. I also figure that since I'm going through the motions why not strip the frame por-15 it and spruce it up a bit. I have two options that I can think of to due this. After finding a good donor first gen standard cab I can either A) strip down the B2 and start piecing it all back together. Or B) I can get a donor B2 strip it to the frame build all my body mounts and flat bed on the donor frame, then swap my parts over. Which way is better? I know there's people out there that have done this. Any info on what to look out for? Thanks!
__________________
Quote:
Tweet
#2 |
Premium Member
Year: 1988
Make: Ford/chevy
Model: Bronco II with 3rd gen front clip
Engine: efi 350vortec
Class: 4x4 full-width 3/4 ton axles
Rep Power: 13 ![]() ![]() ![]() ![]() iTrader: (1)
the ranger cab will literally sit on to the bII frame withh all of the mounts matching except for the rear mounts, which you will be able to grind the heads off the rivets and move them forward on the frame to where they need to be and then drill the frame where the rivet holes were on the mounts and use 1/2" grade 8 bolts to bolt the mount to the frame (which is even stronger than the stock rivets are)
your steering shaft will work, brake master cylinder will bolt right on, electical will all work (only parts not attatched to the cab are the taillights, and fuel pump/sender)........this is a seriously easy swap that has been done, over and over again (you'll find a lot of threads here with extended cab ranger bodies on bII frames)
__________________
whatever you are thinking, i'm probably thinking the opposite. |
Tweet
#3 | |
Premium Member
Year: 99, 02 and 06
Make: Ford /Jeeps/Etc
Model: 99 Ranger 4.0L 2wd 33x12.5 KO tires.
Grand Cherokee 4x4 4.0L
Wrangler X 5.7 Hemi
87 Samurai 4x4
Used For: DD and trail rides
Rep Power: 29 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Quote:
__________________
Straycat 99 Ranger XLT 4 door Supercab lifted 2wd 33x12.5x15 KO's on 15x8 AR polished rims Spare 33 KO mounted flat in bed/custom bed extender |
Tweet
#4 | |
Year: 1988
Make: Ranger
Model: 4x4 2.9l 5speed
Engine: 2.9
Class: 4x4
Used For: getting stuck
Rep Power: 11 ![]() iTrader: (0)
Someone ban this guy for posting stuff that is personally offensive to me. He is obviously on drugs.
__________________
how to pull codes on the EEC-IV. http://www.therangerstation.com/tech_library/OBD_I.html do it! Quote:
Tweet
#5 |
Zombie Killer Truck
Year: 2005
Make: Ford
Model: Ranger Edge
Engine: 5.0 V8
Class: 2WD
Used For: Making fun of full size trucks and eating ricers
Rep Power: 30 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I second that motion. Oh wait......it is straycat so never mind.
__________________
Hoosier your buddy........this guy!!!!!! Freedom is not free. Thank a veteran. 05 Edge of Insanity Build Thread <--------Right Here Things that go bump bump<--------------Audio Upgrade thread Indiana Ranger Owner's Group<-----------For the skinny on what is going down in IN for Ranger Owner's 03 Honda CBR F4i Build<------------------Bike Build Thread |
Tweet
#6 | |
Premium Member
Year: 99, 02 and 06
Wrangler X 5.7 Hemi
87 Samurai 4x4
Quote:
Well, I knew this babe in HC when she was 17 and she was built like that. Man....eye candy galore (that was her last name). When she was 30....."Hang Low Magilicutty' was her new name!!!!!!!
__________________
Tweet
#7 | |
Year: 1988
Make: Ranger
Engine: 2.9
Class: 4x4
Got her number? Hook a brother up.
__________________
Tweet
#8 |
Premium Member
Year: 99, 02 and 06
Wrangler X 5.7 Hemi
87 Samurai 4x4
__________________
Tweet
#9 | |
Year: first gens
Make: Ford right?
Class: 4x4 Extreme
![]() ![]() ![]() Has anyone heard of or seen a first generation green and tan Eddie Baure standard cab?
__________________
Quote:
Tweet
#10 | |
Year: 1988
Make: Ranger
Engine: 2.9
Class: 4x4
I called it and got nothing. Now im as pissed as the original poster.
__________________
Tweet
#11 |
Year: nada
Make: Ford
Model: 2008 F150
Engine: 2.9
Class: 2WD
Used For: teach my boys to not get rid of a Ranger.
Rep Power: 47 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
You put up an Avatar like that and don't expect to get razzed? Chill man - it's part of the game.
Tweet
#12 |
Premium Member
Year: 90 99 84 85
Make: Ford
Model: Ranger
Explorer
BII
Engine: 2.9/5.0/2.8/5.0
Class: 4x4
Used For: Activities that a Focus or an F150 can't do
Rep Power: 18 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (3)
Nope, I don't recall ever seeing an R1 (1st gen Ranger) with the Eddie Bauer package.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
