adsm08
Senior Master Grease Monkey
⭐Supporting Member
Ford Technician
- Sep 20, 2009
- Dillsburg PA
- 4.0 V6
- Tire Size
- 31X10.50X15
Ok, this question covers a lot of ground, but overall I guess this is the best place to post it.
I am planning to do a 4.0 swap in the next year or so, and I'm trying to get everything around ahead of time to make it quicker when I actually start the work.
I would like to get it rigged for OBDII, but keeping my first gen dash is more important to me. Has anyone successfully wired up a 1st gen dash to run an OBDII system? Overall it shouldn't be horrendous, half of it should just be splicing the old connectors into the newer harness, but my biggest concern is the instrument cluster. I know that on some of the newer systems it is a module in it's own right, and if it won't talk back to the PCM the engine won't run. I dunno if that holds true for the older OBDII systems though.
So, has anyone done this successfully, and can I get a copy of your wiring notes?
