Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 07-18-2010, 04:01 AM   #1
BronKitis
Junior Member
Year: 1988
Make: Ford
Model: Bronco II XLT
Engine: 2.9L
Class: 4X4
Used For: A toy
BronKitis is on a distinguished road
Default Blown Rapezza Driveshaft. Repair?
So, I destroyed my factory rapezza shaft. Just so happens I have another one in my garage that came with the B2 when I bought it. It appears to have the same issue as the one I just destroyed but the other end (t-case end) seems fine. I'd like to just replace the bad joint with the good one from the other shaft but I have no idea how to get these things apart. If it's not worth the headache, what is an alternative shaft I could run as a direct bolt in? She's an 88' with roughly 2" of lift. The drive shaft lasted 10 minutes on the trail (only running 31"s, VERY dissappointing) and for anyone who's been to Elbe, WA knows that getting out of a trail there in front wheel drive is a PAIN! Any help is grealty appreciated. Thanks
AJ
BronKitis is offline   Reply With Quote
Old 07-18-2010, 02:32 PM   #2
heptofite
heptofite's Avatar
Year: 1986
Make: Ford
Engine: 2.9
Class: 4x4
Used For: Being Totally Awesome
heptofite is a splendid one to beholdheptofite is a splendid one to beholdheptofite is a splendid one to beholdheptofite is a splendid one to beholdheptofite is a splendid one to beholdheptofite is a splendid one to beholdheptofite is a splendid one to behold
Default
get a shaft from an 84/85 i think, they had a double cardan u-joint at one end and should be a direct fit.
your problem is your lift, with a stock CV shaft, you WILL destroy it if you use a suspension lift.
__________________
Quote:
Originally Posted by Shran View Post
I get a chub just thinking about Volvo taillights fading away into the distance.
Quote:
Originally Posted by adsm08 View Post
I think Rangers are pussy trucks. Mine has gotten me so much pussy, if I have to fix it every day for the rest of my life, it has still earned it's keep.
heptofite is offline   Reply With Quote
Old 07-18-2010, 04:13 PM   #3
BronKitis
Junior Member
Year: 1988
Make: Ford
Engine: 2.9L
Class: 4X4
Used For: A toy
Default
Thanks! Yes, it was definatley destroyed. Does it matter which tranny is in the 84-85? I'm running the FM146 I believe.
Old 07-18-2010, 04:58 PM   #4
heptofite
heptofite's Avatar
Year: 1986
Make: Ford
Engine: 2.9
Class: 4x4
Default
make sure you match lengths.
__________________
Old 07-18-2010, 05:19 PM   #5
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
You need to find one with an A4LD if you actually have a 146. If you have a 145 you need one from a 5-speed. Make sure of your trans before getting one.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 07-18-2010, 05:34 PM   #6
BronKitis
Junior Member
Year: 1988
Make: Ford
Engine: 2.9L
Class: 4X4
Used For: A toy
Default
I'm postive it's a 146. It use to have an AL4D, but it was toast when I got it (hence the 300 dollar price tag!) I threw a 146 in it from a buddies Ranger that was totalled on the side of his house. Free .99! Thanks for the tips!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
