- Nov 4, 2007
- Age
- 54
- Crookston, Mn.
fm145 transmission neutral switch wires are broken off at base
my fm145 transmission neutral switch wires are broken off at the very base, of the switch... is there a way I can make this switch work, if I can screw some small screws into the broken off wires, that are flush with the base of the switch... and then fasten some small terminals to the screws, and attach the switch's wires to these screws, unless I can find another fm145 transmission neutral switch...
