- Jun 17, 2009
I am doing the 4.oL swap into my manual 86 B2. I plan to use the existing trans which is the FM145. ( I have a M50D trans but plan to do that swap later). The 4.0L engine I am using is off a 93 auto Explorer. I know that I need a new flywheel and clutch/pressure plate. The 10 inch on, of course. I am in the process of ordering the parts. I plan to get the fllywheel and clutch set for the 93 explorer. The question: is this compatible with the FM145 trans. Will the FM145 trans input shart fit into the 93 flywheel? Will the clutch slave actuate the pressure plate? I am almost there. After painting the engine compartment I can drop in the 4.0L. Then the wiring begins.
