- Jul 5, 2010
I have a 95 Ford Ranger 4 cylinder 2.3l that is will not start.
First thing I did was replace my battery and splice new connectors on to my battery wires as the battery post were cracked and had eaten away most of the connectors. Did not fix the problem.
Next I determined that every time I go to start my truck fuse #24 on the fuse panel in the passenger compartment blows. I first tried replacing the clutch/starter switch which did not work, and then replaced the starter/relay or solanoid on the fender which did not resolve the problem either.
I can get the truck to start by jumping across the solanoid posts.
I have also checked the continuity of the ignition switch per my Hayne's manual and saw no issue there either.
I can find no evidence of corrosion, melting, burning, or bare wires that would be causing my #24 fuse to blow every time I try to start the truck.
Please help I'm stumped.
