Electrical Help
  • Thread starter Thread starter jhammel85
  • Start date Start date
jhammel85
Guest
Looking for a few suggestions on what to do with some problems I have going on...
I'm looking to fix some corroded wires that I have connected to the connector that runs next to the coil. If you notice, the orange wire and black with a white stripe wire here are barely hanging on. I was thinking about just soldering these wires to the same color on the other side. This takes the convenience of having a plug but its free! Problem is, there are 2 wires on the right connector that do not continue on to the other side??:icon_confused: Any idea what these are? Should something be connected to the other side? I think I may just solder only the two bad wires and leave the wires still connected to the connector alone....See below, what do you think?
Electrical Help
Corrosion!
Electrical Help
My last question is, what is this connector thats hanging under the truck? It seems to come from the same wire loom that runs two wires to the starter. Theres nothing around that it could go to. :icon_confused:
Electrical Help
Note the plugs general area...
Electrical Help
Whew...She's filthy!
I'm pretty sure you can pull those wires and take offthe old plugs and crimp on new ones, not sure what extra wires are for . The wire hanging looks like a transmission plug but looks like you got a manual?good luck
Nope actually an auto.
Any ideas what the plug would go to though? I dont see a thing under there
Thanks!!
Here is one I can solve, for something like that, unplug the connector, and you will see that each wire is held in by an individual clip that holds a metal stop/end connected to the wire, you want to remove the broken one.
Folling that, push a crimp onto wire, solder the ends of the 2 wires together, slide the crimp over the solder point, and crimp both sides VERY tightly, so that it will assure the solder point holds well, and covers the wire.
Following THAT, cover the crimp with electrical tape, and push the end back into the connector, being sure it snaps in. DONE!
As for the hanging wire..... pretty sure its a wire.... not sure to what though =P sorry
That hanging one almost has to be for the transmission. I have the EXACT TRUCK that you have except its a manual, I know my wiring system very well, and I don't have that plug.
Its an odd little plug. I can't think of anything electrical that it would connect to....Plus the truck has been fine for the whole time I've had it. It's always had a firm shift though..
I'm going to have to have another look under there tomorrow!
Thank for everyones help.
As to the mystery wire/connector. Might be for a anti knock sensor...or...a oil level sensor on the oil pan??
I spent some time outside on my lunch break checking things out. It looks like the plug comes from the same loom as the Oil pan sensor for the CPU. Its those two wires connected to this sensor plus this plug. The plug looks to be black but really whos to tell on something this old! I cleaned it the best I could and looks to be solid black.
