Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4-bangers > 4-Cylinder (2000 & Older)
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 06-29-2010, 09:25 PM   #1
caddy
Year: 1993
Make: ford
Model: ranger
Engine: 2.3l
Class: 2wd
Used For: daily driver and trail every now and then
caddy is on a distinguished road
Default HELP PLEASE.... replaced crank sensor, now no injector pulse
A week ago I took my 93 2.3l ranger out for a drive i hit a few puddles on the way no big deal at the time, and about 5-10 minutes later the truck started to sputter at idle so I raised the rpm to about 2000 and it sounded fairly smooth then I let off and it started sputtered again, then I clicked the a/c on without thinking, and it died. I got out of the truck and immmediatly checked the air filter to see if I sucked up water but it was dry, and so was the throttle body, I pulled the dipstick to see if maybe there was some water in the oil, and nothing. So after that I checked to see if there was spark at the coils and there was not. So I towed it back to my apartment with my brothers ranger. That weekend I started to diagnose it and found that I had a bad crank sensor, so I replaced it. And when I tried to crank it up it still will not start. So once again I checked the spark at the coils, and I have spark, so I check to see if there was injector pulse and there is nothing So I have spark now but no injector pulse but I can smell fuel. ANY IDEAS??? help would be much appreciated because the truck is my daily driver and I love driving it
caddy is offline   Reply With Quote
Old 06-30-2010, 12:55 AM   #2
Duane867
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
Used For: Daily driver. Fishing vehicle. Use from time to time to run down crack heads.
Duane867 is a jewel in the roughDuane867 is a jewel in the roughDuane867 is a jewel in the rough
Default
Did you use any kind of positioning tool when installing the new crankshaft sensor ?
Duane867 is offline   Reply With Quote
Old 06-30-2010, 03:33 PM   #3
caddy
Year: 1993
Make: ford
Model: ranger
Engine: 2.3l
Class: 2wd
Default
no i didnt I marked everything and double checked the timing it was all good, after installation. Im thinkin maybe The camshaft sensor is bad but Im not sure.
Old 06-30-2010, 04:28 PM   #4
red85
red85's Avatar
Year: 1985
Make: Ford
Model: Ranger
Engine: 306 ci
Class: 2WD Street
Used For: making noise and burning gas
red85 is on a distinguished road
Send a message via MSN to red85
Default
Check your wiring. You may have an open/short. Take your time and use a meter not a test light!
__________________
Professional Auto Service Tech
1996 Ranger XLT - 3.0 A4LD
1985 Ranger S - 306 ci/C4 (12.96 1/4)gone but not forgotten
1994 Ranger XL - 2.3T/M50D R1 (sadly retired now - Salt cancer got her)
2008 Ranger Sport - 3.0/M5OD R1
Don't ask a question if you don't want to hear the answer!
Putting brains before dollars since 1970
red85 is offline   Reply With Quote
Old 06-30-2010, 08:23 PM   #5
caddy
Year: 1993
Make: ford
Model: ranger
Engine: 2.3l
Class: 2wd
Default
I know it Ive been using a digital multi-meter FOR SURE lol. But today when I went out to the truck to check it out again I was cranking it and I could smell fuel real bad, so I took the air filter off and I could really smell gas, so I checked out the throttle body and that sucker reeked off gas. So I pulled out a spark plug and there was gas on it. So idk im stumped I have spark, I have air, and apparently I have fuel but it wont start. I need to get this thing fixed quickly this truck is my daily driver.......
Old 07-01-2010, 12:12 AM   #6
scotts90ranger
scotts90ranger's Avatar
Year: 1990
Make: Ford
Model: Ranger
Engine: 2.3 Turbo
Class: 4x4
Used For: holding down the driveway
scotts90ranger has a spectacular aura aboutscotts90ranger has a spectacular aura aboutscotts90ranger has a spectacular aura about
Default
other option is the timing belt skipping a tooth that would do it
__________________
converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears!
Send e-mail instead of PM, box full...
scotts90ranger is offline   Reply With Quote
Old 07-01-2010, 09:47 AM   #7
Duane867
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
Default
Dosen't the height of the crank sensor have to be set with the tool it comes with ?
Old 07-01-2010, 10:23 AM   #8
caddy
Year: 1993
Make: ford
Model: ranger
Engine: 2.3l
Class: 2wd
Default
true I'll check the timing for sure...
Old 07-01-2010, 10:28 AM   #9
caddy
Year: 1993
Make: ford
Model: ranger
Engine: 2.3l
Class: 2wd
Default
The crank sensor doesnt have an alignment there is 2 bolt hole in it with no adjustment on it. When I bought the new one it didnt come with any sort of alignment tool. Im pretty sure the cam sensor needs an alignment tool for certain models (california models). But I cant even find where the cam sensor is on the truck. I printed out diagrams off alldata looked it up in the book and I did some pokin around, and I still cant find it, all the diagrams that I have say the cmp is near the oil filter on the drivers side of the block but I do not see it on my truck.....
Old 07-01-2010, 03:42 PM   #10
Duane867
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
Default
I bet your right in that its that cam sensor that takes the positioning tool...
The cam shaft position sensor is located on the right side of the head as you are facing the engine hood up.
Old 07-01-2010, 06:36 PM   #11
caddy
Year: 1993
Make: ford
Model: ranger
Engine: 2.3l
Class: 2wd
Default
thats the same diagram that I have and i looked in those spots and nothin idk what the deal is lol
Old 07-02-2010, 12:39 AM   #12
Duane867
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
Default
Oh its there....
I'll check under the hood in the morning and snap off a photo for you to show the location on my truck. Same engine and year. Mines a 5 speed.
Have you pulled any codes yet ?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
