Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 3.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 08-18-2007, 06:22 PM   #1
flaymon1
Junior Member
flaymon1's Avatar
Year: 1998
Make: Ford
Model: Ranger XLT
Engine: 2.5
Class: 2WD
Used For: Tire testing and road racing :)
flaymon1 is on a distinguished road
Default noise 3.0?
A fellow Ranger owner left this question on mycardomain can you guys give any advice on what it could be?
"hey u seem to know a lot about rangers. i have a 1998 ranger 3.0 and after reaching 100 000 miles and changing the oil. ever time i drive now it makes a ticking sound that goes with the engine rps. this seem to be a common problem with the 3.0s and ford says they don't know what it could be. i thing it might be the oil pump because it doesn't sound like a valve do u know anything about this ? thanks"
http://www.cardomain.com/id/cky033
flaymon1 is offline   Reply With Quote
Old 08-18-2007, 07:55 PM   #2
Wicked_Sludge
Wicked_Sludge's Avatar
Year: 1993
Make: Ford
Model: Ranger, Flareside
Engine: 3-point-GO
Class: 4x4
Used For: Attracting the ladies
Wicked_Sludge will become famous soon enough
Send a message via MSN to Wicked_Sludge
Default
you should refer him to TRS so he can get other future issues solved here too
did he check his oil to make sure the right amount was put it? if it was his oil pump, his dummy oil gauge would indicate low pressure (and his engine would likely be seized by now). sounds like a collapsed lifter to me.
__________________
As seen on the internets!
Quote:
Originally Posted by Hahnsb2 View Post
Dyno sheet or GTFO
Quote:
Originally Posted by Ranger Dave (B25) View Post
The call was for scantily-clad women. A Certificate of Boob Authenticity was NOT specified.
Quote:
Originally Posted by Grant Imahara
I'm not sure if we have the right stuff; I'm just hoping we don't have the wrong stuff.
__________________________________________________ ____________________________________
Wicked_Sludge is offline   Reply With Quote
Old 08-18-2007, 10:48 PM   #3
Southern3.0
Southern3.0's Avatar
Year: '96
Make: Ford
Model: Ranger
Engine: 2.3, what a turd...
Used For: Punishment
Southern3.0 is an unknown quantity at this point
Default
+1 on the lifter
All of a sudden after 116,000 mi My truck would tick all the time even when it was hot but I ran some seafoam thru the oil and now it only dose it when its cold after it sits for a day
__________________
'95 Ranger, single cab, 4 cyl 5 spd, 2wd
'96 Ranger single cab, 4 cyl 5 spd, 2wd. sold.
'02 Edge...Wrecked it
'91 Ranger, picked it up for $300, sold it for $2500
Southern3.0 is offline   Reply With Quote
Old 08-19-2007, 11:17 AM   #4
flaymon1
Junior Member
flaymon1's Avatar
Year: 1998
Make: Ford
Model: Ranger XLT
Engine: 2.5
Class: 2WD
Default
I gave him the TRS address on his Cardomain.
__________________
~BigR~
Those who say it can't be done are usually interrupted by those doing it!
2.5"SychoBilly Ranger"
Old 08-29-2007, 09:00 PM   #5
Jordan94
Junior Member
Jordan94's Avatar
Year: 1994
Make: Mazda
Model: B3000
Jordan94 is on a distinguished road
Send a message via MSN to Jordan94
Default
I am having the same trouble with my 1994 Mazda B3000 4x4 SE. This knocking/ticking noise only starts when the truck has been running for about 5 minutes and continues all day, There is no check engine light and this is starting to worry me as its my only ride to school. Would this Seafoam be worth a try first and if not possibly a lifter gone????
Jordan94 is offline   Reply With Quote
Old 08-29-2007, 10:22 PM   #6
Southern3.0
Year: '96
Make: Ford
Model: Ranger
Default
You might wanna give it a try, If you do put seafoam in the oil make you sure you change the oil 100 mi after you add it.
From what your saying it might be something worse like a rod bearing, after the oil warms up and thins out a little the clearances might be to much but who knows
__________________
Old 08-30-2007, 08:21 AM   #7
Jordan94
Junior Member
Jordan94's Avatar
Year: 1994
Make: Mazda
Model: B3000
Default
This Seafoam stuff how to you put it in iv never heard of it or seen it yet any directions for it? Im going to go to the dealer in a few so there gonna have a look ill post back what they say
Old 08-30-2007, 09:23 AM   #8
Jordan94
Junior Member
Jordan94's Avatar
Year: 1994
Make: Mazda
Model: B3000
Default
The ford dealer says it could be timing or distributor but thinks its the lifter. I'm booked tomorrow first thing in the morning so there gonna take a good look and find out what it really is.
Old 09-01-2007, 04:48 PM   #9
Jordan94
Junior Member
Jordan94's Avatar
Year: 1994
Make: Mazda
Model: B3000
Thumbs down
Well after 1400 Canadian dollars I have all new lifters and throttle linkage plus Mobil 1 oil change. Turns out my truck had been running on 2 collapsed lifters and the guy that i just recently bought it off did something which i think was seafoam to make the knocking temperaly go away so when i test run and etc it seems fine. All I can say is be carfull when buying used vehicles. No more knocking now
Old 09-01-2007, 08:16 PM   #10
Wicked_Sludge
Year: 1993
Make: Ford
Engine: 3-point-GO
Class: 4x4
Default
at least you got it fixed. it should be a pretty reliable rig for a while now.
__________________
Dyno sheet or GTFO
Old 09-02-2007, 01:04 AM   #11
Southern3.0
Year: '96
Make: Ford
Model: Ranger
Default
Ahhhh that sucks, glad you got it fixed tho
__________________
Old 09-10-2007, 10:17 PM   #12
RedRanger
RedRanger's Avatar
Year: 2001
Make: Ford
Model: Ranger, with 4.10 ring gears and Ford Racing Track Lock
RedRanger is on a distinguished road
Default
Hey I dont know if I have the same knocking but I just thought I would ask. When ever I put my 2001 3.0L under any kind of load as in flooring it or hauling something the engine will start knocking, but only for a short period of time. And I dont know what it is but I think its spark knocking, what sould I do for that?
RedRanger is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
