Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 4.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 01-06-2008, 10:13 AM   #1
cwcnoles03
Year: 1996
Make: Ford
Model: Ranger EXT
cwcnoles03 is on a distinguished road
Default Spun Main Bearing?
So I have a 96 4.0L Ranger. I let my father use it for about a month while I was at school and now there is a loud knocking sound under the hood and I don't think it's even driveable. I haven't tried nor have I put a stethoscope up to it, which from reading other forums, is what I should do? However, what I'm trying to determine is whether or not my dad's prognosis could be viable. He believes that it is a spun main bearing. SO my question is, what does a spun main bearing sound like? And what does a busted rod sound like? This sound is pretty freaking loud, and there's chemical/burning smell upon disengage.
Thanks
cwcnoles03 is offline   Reply With Quote
Old 01-06-2008, 01:28 PM   #2
Kona
Kona's Avatar
Year: 1991
Make: Ford
Model: Ranger Super Cab
Engine: 4.0L
Class: 4X4
Used For: everything
Kona is on a distinguished road
Default
Contact a oil analysis place, get a sample kit and send a sample back to them. Probably cost $20 - $30 dollars and they can tell what is worn by the metals and chemicals in the oil. Or you can get a mechanic .
__________________
91 Ranger XLT SCab 4.0L 5 Spd,4.56 gears, Spartan locker ,Skyjacker 6" w Skyjacker radius arms, Deaver G50 r springs, Belltech shackles, Flowmaster 40,Winch, 33's of some sort
Kona is offline   Reply With Quote
Old 01-06-2008, 06:43 PM   #3
MAKG
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
MAKG will become famous soon enough
Default
Well, one way to tell the difference between a broken rod and a spun main bearing is a cranking compression test. The broken rod will have zero compression....
But there are other possiblities, and an automotive stethoscope really is the right thing to do first. These are cheap.
Kona, how can oil analysis tell which bearings are thrashed? They are all made out of the same material.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 01-06-2008, 07:03 PM   #4
fordwheelinman
fordwheelinman's Avatar
Year: 1994
Make: Ford
Model: Explorer 4 door
Engine: 4.0L
Class: 4x4
Used For: DD
fordwheelinman is on a distinguished road
Default
Drain your oil into a dish pan or some other clean pan. Shine a very bright light into the pan of oil and see if you see sparkles in the oil. Try blowing into the pan slightly and you should be able to tell something right away. If the oil looks like it has glittery material in it, youve wasted a bearing, or more. If youve broken a rod, the whole motor will be shaking like hell when you run it, and you will visibly see it shaking back and forth terribly. A broken rod will result in a massive imbalance in the rotating mass of the engine, thus casing the violent shaking. Hope this is some help......and that MAKG doesnt think im too far off. Im kidding of course.
__________________
*1994 Explorer 4 door- 4L ohv, FACTORY M5OD, working electric 4x4, new DD, awaiting 31x10.50's on black stock wheels
*1978 F150- 4x4, 400 V8, C6, 31x10.50x15 adventuro all terrains on stock steels-towing, 33x12.50x15 BFG All terrain on mag 15x8.5, custom in bed gooseneck, waiting on custom flatbed
*1989 Bronco II-Converted 4x2 to 4x4 with 2.9 bored .060, ported/polished heads, port matched manifolds, a4ld, man 1350, D28/7.5 4.10's in both L/S in rear: waiting on motor
fordwheelinman is offline   Reply With Quote
Old 01-06-2008, 08:38 PM   #5
Silverado
Junior Member
Year: 1998
Make: Ford
Model: Ranger XLT
Silverado is on a distinguished road
Default
From my experience years ago, a busted rod sounds like an angry midget is inside your engine with a sledgehammer having a temper tantrum.
A spun bearing sounded like a rifle being discharged in full auto (I think what you guys call a Class 3) inside the crankcase.
Did that help? LOL
__________________
98 Ranger XLT Regular Cab Flareside 3.0 4X4 310,000KM pain in my ass!
Silverado is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
