Go Back   The Ranger Station Forums > TRS Photo & Video Galleries > Your Garage > Off-Road Rangers Under Construction
Notices
Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress.
Post New Thread Reply
Thread Tools Display Modes
Old 06-18-2010, 06:19 AM   #1
rkneeshaw
rkneeshaw's Avatar
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: Winter beater, wheelin with my son
rkneeshaw will become famous soon enough
Default My Truck Transformation - 94 4x4
Well it feels like much more of a transformation to me. This was her the day I bought her for $1000.
Before:
This is her, 6 months and $2000 later:
Doesn't look too much different from the photos, but from behind the wheel, its a totally different truck. For fun, I've been keeping my to-do list along the way, here it is:
X Clean glass
X Wipe down surfaces
X Remove stickers
X Attach tailgate latch cover
X Remove bug deflector
X Remove mud flaps
X Clean MAF
X Steering cover
X Replace Wipers
X Haynes manual
X Replace tie rod assembly
X Replace ball joints
X Replace radius bushings
X Replace outer u joints
X Replace Heater blower
X Replace PCV
X Replace air filter
X Replace Headlights
X Shampoo carpet and seats
X Change transfer case fluid
X Change coolant
X Change spark plugs
X Replace shocks
X Replace leaf hangers
X Replace leaf shackles
X Install stereo
X Replace belt tensioner
X Remove mud flap mounts
X Fix driver wiper
X Replace transmission
X Replace 4x4 hubs
X Install coil spacers
X replace clutch
X replace slave cylinder and bearing
X Wheels and Tires
X Alignment
X Remove purple window tint
X replace speedometer cable
X Replace speed sensor
X Exhaust leak
X Replace LH spindle
X Change differential seals
X Replace speakers c6882ie
X Replace starter
X Change front shaft U-joint
X Fix vacuum leak
X Brakes
X Replace exhaust hanger
X Fan clutch
X O2 sensors
X Replace dash trim
X Replace drivers door panel
X Powerwash carpet
X Replace seats
X Install speaker brackets
X Fix ash tray
X Replace fuel door
X Reseat front bumper
X Rearview mirror
X Steering tension adjustment
X Pedal covers
X Coolant temp sensor
X Front valance w/fog holes
X Wire aux light switches
X Install fog lights
X Fix POS battery terminal
X Powerwash passenger door panel
X Replace passenger door lock
X Replace passenger door mirror
X Replace passenger window sweep
X Ignition lock cylinder
X Replace drivers door mirror
X Remove ABS indicator bulb
X Replace spark plugs again
X Replace spark plug wires
X Remove RABS valve
X Front brake lines
X Flush brake fluid
X Rebuild cardan joint in front drive shaft
X replace battery
X Replace battery terminals
X replace negative bat cables
X replace starter again
X replace speedo gear
X Install tow hooks
X Fix 4x4 lighted switch
So in short, the front end was all redone, replaced transmission, new brakes, 2" lift and level, 32" tires on rockcrawlers, and a whole lot of love
94 Ranger 4x4
4.0L V6
5-speed manual
2" leveling coil spacers
1" lift shackles in the rear
32x11.5x15 BFG T/A KO's on 15x8 rockcrawlers
187,000 miles and running strong
rkneeshaw is offline   Reply With Quote
Old 06-18-2010, 08:03 AM   #2
railman
December 2011 OTOTM Winner
Year: 1996
Make: Ford
Model: Ranger SC 4X4
Engine: 4.0
Class: 4x4 Extreme
Used For: everything
railman will become famous soon enoughrailman will become famous soon enough
Default
i like....
and man have ya knocked out quite a list.....
keep up the good work....
l8r, John
__________________
SAS with leaves, KP HP D60 front, D60 FF rear, 4.88's, 39.5x13.50x17" Bias Iroks, 17" Allied Beadlocks, winch, and a few dents and scratches......
railman is offline   Reply With Quote
Old 06-18-2010, 09:47 AM   #3
Ranger Kip
Ranger Kip's Avatar
Year: 05,98,01,98,13
Make: Ford,Suzuki,Inf
Model: F150,Ranger,Swift,Q45,Taurus,Elantra
Engine: 4.6,2.3,1.2,4.8,4.0,2.5
Class: DD, Fixing, DD, Fixing
Used For: listed up there
Ranger Kip will become famous soon enoughRanger Kip will become famous soon enough
Send a message via AIM to Ranger Kip Send a message via MSN to Ranger Kip Send a message via Yahoo to Ranger Kip Send a message via Skype™ to Ranger Kip
Default
nice work!
buy the old rims off you?
__________________
Quote:
Originally Posted by 85_Ranger4x4 View Post
a well aimed bird crap would make most of those around here implode.
PROJECTS
84 One Eye'd Beast - Status: Junked
79 Iron Horse - Status: Sold
95 Tan Tortoise - Status: Replacing Brake Lines
Ranger Kip is offline   Reply With Quote
Old 06-18-2010, 11:28 AM   #4
bcost882
bcost882's Avatar
Year: 2000, 2011
Make: Ford
Model: Ranger XLT, Fiesta
Engine: 3.0L, 1.6L
Class: FX2, Tiny
Used For: Enforcing vehicular darwinism
bcost882 is on a distinguished road
Default
looks pretty cool, i like it
__________________
(2000 XLT 2wd X-cab, 3in spindles, Flowmaster delta40, Explorer 8.8in w/3.73s and crap-lok, 'sploder leafs, Belltech 6400s, 31x10.5r15 Michelins)sold
I'm not afraid to beat on my junk!
Quote:
Originally Posted by Frank The Tank View Post
You havent' lived!!!! Wake up and breath the fresh air........ open your peepers and go tackle the world.
bcost882 is offline   Reply With Quote
Old 06-18-2010, 04:39 PM   #5
straycat
Premium Member
straycat's Avatar
Year: 99, 02 and 06
Make: Ford /Jeeps/Etc
Model: 99 Ranger 4.0L 2wd 33x12.5 KO tires. Grand Cherokee 4x4 4.0L Wrangler X 5.7 Hemi 87 Samurai 4x4
Used For: DD and trail rides
straycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud of
Default
Me likes it alot, Bro!!!!!!
__________________
Straycat
99 Ranger XLT 4 door Supercab lifted 2wd
33x12.5x15 KO's on 15x8 AR polished rims
Spare 33 KO mounted flat in bed/custom bed extender
straycat is offline   Reply With Quote
Old 06-19-2010, 09:36 PM   #6
rkneeshaw
rkneeshaw's Avatar
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
Thanks guys. It went from being a pile of poo to a fun toy that has a special place in my heart... much to the frustration of my wife
Old 06-25-2010, 09:32 PM   #7
cr_the_machinist
Gettin' Skool'd
cr_the_machinist's Avatar
Year: 1999
Make: Ford
Model: Ranger XLT Sport
Engine: 4.0L OHV
Class: 4x4
Used For: Daily Driver
cr_the_machinist is on a distinguished road
Send a message via AIM to cr_the_machinist
Default
Your truck looks good. The new tires and wheels make it look great.
cr_the_machinist is offline   Reply With Quote
Old 06-25-2010, 11:25 PM   #8
Ranger Sport Honduras
Solid Axled yo!
Ranger Sport Honduras's Avatar
Year: 1999
Make: Ford
Engine: 2.5 (5spd)
Class: SAS 4X4
Used For: Everything and more...
Ranger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond repute
Send a message via MSN to Ranger Sport Honduras
Default
good work!!! looks awesome
__________________
click for:
Ranger Sport Honduras Level II (My D30 SAS 4WD)
Mini Power Stroke (My bro's Crew Cab 4WD Ranger--Slow build)
Ranger Militia
Cardomain(All the trucks)
Ranger Sport Honduras is offline   Reply With Quote
Old 03-22-2011, 05:51 PM   #9
eduardo95
eduardo95's Avatar
Year: 1995
Make: ford
Model: ranger xlt
Engine: 2.3 I4
Class: 2WD Off-Road
Used For: getting to work
eduardo95 has a spectacular aura abouteduardo95 has a spectacular aura about
Default
You dont have a bodylift right.?
__________________
3" body lift, 31" mt/s, Cragar soft 8s wheels, 10" subwoofer enclosure with kenwood head unit and speakers. Pro comp auxiliary lightning. 4.10 gears.
eduardo95 is offline   Reply With Quote
Old 03-23-2011, 08:29 AM   #10
rkneeshaw
rkneeshaw's Avatar
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
Nope, no body lift, just 2" coil spacers in the front and a 1" lift shackle in the rear. 32's on 15" rims with 3.75" backspacing. Going to install my JD 3" kit this weekend though
EDIT: To be fair, my rear leafs are jacked up and the passenger side of the truck sits slightly higher than the drivers side, so the pics here might show some slightly generous wheel wells.
__________________
1994 Ford Ranger 4.0L 4x4
3.5" of James Duff Stage 1 | 32x11.5x15 BFG AT's | 15x8 cragars | stainless brake lines
Sony and Kenwood sound | gen4 seats | tow hooks | procomp fogs
[ Build thread ]
Old 03-23-2011, 11:50 AM   #11
eduardo95
eduardo95's Avatar
Year: 1995
Make: ford
Model: ranger xlt
Engine: 2.3 I4
Class: 2WD Off-Road
Default
Looking forward to it. Post pics as soon as possible
__________________
Old 03-28-2011, 09:16 PM   #12
rkneeshaw
rkneeshaw's Avatar
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
Making slow but steady progress on the lift. Here are a few pics so far
Stock spring next to James Duff spring:
Passenger side (spring isn't set yet in the coil bucket, shock not connected, etc):
Radius arm drop brackets installed:
Drivers side almost complete and drop pitman arm installed:
Finished up the front end tonight, but didn't get any updated pics. Just need to bleed the brake lines. Replacing the rear leafs and shocks tomorrow, then an alignment and a test drive. Replaced the pivot and leaf bushings with polyurethane replacements by Energy Suspension, and installed Moog's latest radius arm bushings that are supposed to stand up to the heat of the exhaust manifold but flex as good as the stock rubber bushings.
The only bushings not replaced were the sway bar bushings and end links. I'm still deciding whether or not I want to keep the sway bar connected so for now it stays as is. I really wish there were extended end links available that weren't priced to rape.
I've got to say, replacing the pivot bushings is a bitch. I lucked out and was able to install this lift at a shop so I have extensive tools and a torch. Had to use it on couple occasions. Also the pitman arm nut requires the strength of a guerrilla to remove. Actually a guerrilla with 8ft of cheater pipe. And using a lift is a gift from god.
__________________
[ Build thread ]
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
