Go Back   The Ranger Station Forums > Styling & Electrical > Lighting/Illumination
Notices
Lighting/Illumination This forum is for headlamps, auxillary lighting, interior lighting, and LED conversions.
Post New Thread Reply
Thread Tools Display Modes
Old 06-13-2010, 12:23 AM   #1
snomaker321
snomaker321's Avatar
Year: 2004
Make: Ford
Model: Ranger EDGE
Engine: 4.0 SOHC
Class: 4x4
snomaker321 is on a distinguished road
Send a message via AIM to snomaker321 Send a message via MSN to snomaker321 Send a message via Yahoo to snomaker321
Default 04+ gauge leds
I want the green to be blue and the red to stay red. Id this doable? What do I need to do? thanks
__________________
After many months of searching, I know have a 2004 ranger edge in my driveway!
snomaker321 is offline   Reply With Quote
Old 06-14-2010, 12:54 AM   #2
snomaker321
Year: 2004
Make: Ford
Model: Ranger EDGE
Engine: 4.0 SOHC
Class: 4x4
Default
anyone? cant find any info on these gauges
figures, once i learned pretty much everything i needed to know about the 3rd gen rangers, i went out and bought an '04
__________________
Old 06-14-2010, 11:13 PM   #3
Crane
Junior Member
Crane's Avatar
Year: 2004
Make: Ford
Model: Ranger XLT
Engine: 4.0L SOHC
Class: 4x4
Crane is on a distinguished road
Default
I'm actually in the same boat, I would love to have some blue gauges, but just haven't gotten around to seeing what kind of bulbs I would need.
I have a feeling that the red needles would turn a purpleish color with blue leds behind them.
If you wanted to keep the red needles, you could use white leds, which would result in the numbers being white (if you removed the film) or blue/green (not sure what color the film is, as I haven't seen it before, just speculating).
Crane is offline   Reply With Quote
Old 06-15-2010, 08:23 AM   #4
Ranger Sport Honduras
Solid Axled yo!
Ranger Sport Honduras's Avatar
Year: 1999
Make: Ford
Model: Ranger XLT Sport
Engine: 2.5 (5spd)
Class: SAS 4X4
Used For: Everything and more...
Ranger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond repute
Send a message via MSN to Ranger Sport Honduras
Default
get replacement leds, and replace the bulbs with em. i think that ull need to remove the green film on it.
__________________
click for:
Ranger Sport Honduras Level II (My D30 SAS 4WD)
Mini Power Stroke (My bro's Crew Cab 4WD Ranger--Slow build)
Ranger Militia
Cardomain(All the trucks)
Ranger Sport Honduras is offline   Reply With Quote
Old 06-15-2010, 10:41 AM   #5
snomaker321
Year: 2004
Make: Ford
Model: Ranger EDGE
Engine: 4.0 SOHC
Class: 4x4
Default
Quote:
but will i be able to keep the red? I havent been able to find any info for this style of cluster. Maybe i could just change the color of the film and use white leds
__________________
Old 06-19-2010, 11:08 PM   #6
snomaker321
Year: 2004
Make: Ford
Model: Ranger EDGE
Engine: 4.0 SOHC
Class: 4x4
Default
bump.
any info on these type of gauges is appreciated
__________________
Old 06-20-2010, 12:58 AM   #7
Solid Axled yo!
Year: 1999
Make: Ford
Engine: 2.5 (5spd)
Class: SAS 4X4
Default
Quote:
if u use white leds u just need to remove the green film. the needles will still be red
i think that best option is gettin 1 led and test it to see how the needle looks with it
__________________
click for:
Ranger Militia
Old 06-21-2010, 07:23 AM   #8
94bigsteele
94bigsteele's Avatar
Year: 1994
Make: ford
Model: ranger
Engine: 4.0
Class: 4x4
Used For: what dont i use it for?
94bigsteele is on a distinguished road
Default
holy sh!t you just sounded like me right there lol
__________________
94 -4x4 ext cab 4.0 with 335,000 miles,
craiger soft 8 black,rough country level coils
thrush welded,31x10.5 general HTS,warn manual hubs.
95 -4x4 extcab 4.oh! manual- sold
00 - gmc sierra 2wd ext cad short bed stock
94bigsteele is offline   Reply With Quote
Old 06-21-2010, 08:12 AM   #9
Scrambler82
Scrambler82's Avatar
Year: 2003
Make: Ford
Model: Ranger Edge
Engine: 3.0
Class: 4x4
Used For: DD
Scrambler82 is on a distinguished road
Default
R these Gauges similar to the 03 setup ?
If so then you can leave the red and scrape the green off but you will end up with white translucent numbers.
Add a light coat of the glass paint and then some white LED Lighting all should be OK but the White remaining on the numbers will lighten up the Blue a little.
Don’t put on too many coats of the glass paint because it gets thick fast.
If you are going to use LED Bulbs, use taller Bulbs, the ones with more of the SMD type of LEDS in them. What that does is get the LEDs closer to the Gauge ack Surface and to adds extra light through out the Cluster, maybe one of the 8 or 10 LEDs to a Bulb.
The SMD LEDs with 8 or 10 LEDs will cost a little more but IMHO add the light where needed. Std one LED Blubs do not spread the lighting as needed.
If you use BLURE SMD LED Bulbs then the RED will turn out PURPLE, if you can live with that then go for it.
Good Luck and post some pic of the end results and what you use for LEDs.
__________________
Do It Right The First Time !
Scrambler82
N1MAU/W1IO
Scrambler82 is offline   Reply With Quote
Old 06-21-2010, 11:15 AM   #10
Solid Axled yo!
Year: 1999
Make: Ford
Engine: 2.5 (5spd)
Class: SAS 4X4
Default
his cluster is like this one. but with black backgrounds.
seems to me that if u go with blue leds it will look like this
or u could sand down the green film and do your own blue film with paint or blue transparent film and use white leds
__________________
click for:
Ranger Militia
Old 06-21-2010, 10:32 PM   #11
snomaker321
Year: 2004
Make: Ford
Model: Ranger EDGE
Engine: 4.0 SOHC
Class: 4x4
Default
not sure exactly what you mean. Do i scrape off the green and then the paint makes like its own film or do i paint the green with blue glass paint?
Id rather not do it than have purple. I like them as is but i think blue would look sick!
Actually RSH, that is my gauge exactly.
The problem with the second pic you posted is that those gauges dont have the red. Im just not sure how having different colors affects it.
__________________
Old 06-21-2010, 11:20 PM   #12
Solid Axled yo!
Year: 1999
Make: Ford
Engine: 2.5 (5spd)
Class: SAS 4X4
Default
actually it has red and it looks purple lol
it has red on the empty fuel line and hot engine temp.
also on the low oil pressure line and both lines on the battery gauge.
i think your best option is with pic #3
sand out the green and paint it with blue and use white leds or white bulbs. that way the red will stay red. just dont sand the red lol
__________________
click for:
Ranger Militia
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
