| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1986
02'
Make: ford
Model: ranger
f150 fx4
Engine: 2.9 & 5.4
Class: 4x4
Used For: exercise and DD & hauling college kids stuff
Rep Power: 14 ![]() iTrader: (3)
I get this scraping sound / noise after I installed the distributor on my 2.9, when tuning over by hand.
(It hasn't been run yet after a rebuild)...it doesn't last long.... just a certain area. ![]() ![]() I thought it I got it corrected prior to the oil pan going on....I'm just about ready to install back into the truck...attaching the flywheel/ringear. so I'm rolling this baby around by hand to get the nuts started. apprently didn't roll it over completely. ![]() ![]() I'm pretty sure/confident it wasn't present prior to the distributor. (ya know how you 2nd guess this kinda thing if it was yours) Is there a special tool & or procedure to aligne the drive shaft from the oil pump to the bottom of the distribtor?? the one way washer on the drive shaft could be just riding bottom of the cam gear???? any input ?? appreciated
__________________
IMenRiched By the power of Lord Jesus ![]() 2 are willing to die for you. one is a soldier, but the 1st was Jesus Christ ~few appreciate either~ |
Tweet
#2 |
Year: 1986
02'
Make: ford
Model: ranger
f150 fx4
Engine: 2.9 & 5.4
Class: 4x4
Well....It must have been the "one way keeper washer" on the drive shaft between the distrubtor and the oil pump. It may have gotten pushes higher up the shaft towards the distributor/ cam gear...once I put oil in it....& got the engine connected back to the tranny, things quieted down...still turning over by hand. I suppose this washers just got pushed out of the way too so it didn't rub any more.
the few times that I did turn it over would have been barely enough to prime the oil pump....let alone get oil to the upper regions of the cam and valve train. If there are other who have had simular experiance....I'd like to hear it. thanks again
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
