How to remove the headlight knob in my 93?
LoneRanger93
15+ Year Member
The headlight knob on my truck does not like to operate the way it should, you have to "jiggle" it a bit to get the lights to come on, Since it's a cheap part I'm thinking it needs to be replaced. How does the dash come off and what holds the knob or switch in place?
Thanks!
its been a while...so here goes from memory:
you need to pull the trim peice that surrounds the switch away from the dash...it just clips on. this will gain you access to the actual headlight switch. on the bottom of the switch there is a small metal button, push this and it releases the knob (it may take some wiggling). then just remove the 2 or so bolts holding the switch on and unplug the wiring harness.
Ok i got to the knob and the switch, I can't really tell just from inspection if the knob or the switch is bad, should I replace them both or just the switch?
LMCtruck.com sells both the parts for $20 a piece
The knob has a clip on it. all you have to do is put a pick tool or something similar onto the back of the knob (right next to the shaft) and the knob will slide right off. If you look carefully there is a little square notch that shows you just were to release it.
There is also a botton on the side of the switch that releases the shaft. Pull the shaft all the way out(headlight on position), push the button, then pull the shaft the rest of the way out.
check your wiring harness for the switch too i guess i'm about the only one lucky (or unlucky i should say) to have the switch go bad (actually it's the harness making the switch go bad) in all three of my trucks. 4-5 for the 84, 3 last i remembered for the 93 and on my 2nd one for the 91.
There is no need to replace the knob, I can't even think of anything that would make it go bad. Just get the switch, I think I paid 25 bucks for mine at NAPA.
I am assuming you already got the dash off? If you haven't, be careful of the little clips that hold it on.... I tried taking my dash off (to replace the switch) and broke half of them so I just said screw it, I ripped the other ones off to and just put three black screws in to hold it on. You can't even tell they are there and I think it holds the dash face on better than the clips.
Are you talking about how many light switches you've put in each truck? If so, I wouldn't doubt, fords older light switch designs are kinda funky.
I am on my second, my dad said he can't even remember how many he has had to replace over the years.
Well I replaced the switch and if it helps anybody here is how I went about it:
Bought a new headlight switch at autozone for 13 dollars
Unscrewed 2 torx screws for the ashtray and popped off the dash
Unscrewed 2 torx screws for a bracket holding the headlight switch
Popped off the headlight knob by pushing the button on the switch
Unplug old switch and plug in new one
It was quite simple!
Good deal; hope that it fixed your light problem.
Unscrewed 2 torx screws for the ashtray and popped off the dash. Unscrewed 2 torx screws for a bracket holding the headlight switch. Popped off the headlight knob by pushing the button on the switch. Unplug old switch and plug in new one.
I had more problems than you, for my 1994 headlight switch. (Mine broke internally and would not pull or push, except with great difficulty; thought the lights would remain on forever.)
1) I disconnected the battery. Set the brake and put the tranny in 1st gear, if you have an automatic. This allows the panel to clear the shifter.
2) Remove the 2 torx screws from the ash tray. Pull out the knob and you'll see a small natch. Use a small screwdriver or pick and lift the clip, to slide the knob off.
3)Use care when unsnapping the gray dash section, because the clips are fragile. (Some of mine were broken off from a previous repair.) Now, there are 2 wiring harnesses attached to this panel, which operate nothing (on my rig). Detach these. With the truck in 1st, the panel will flex enough to allow it to be removed.
4)Thee is a plastic trim ring (behind the knob) that must be unscrewed a couple turns to allow some flex in the switch... if the bracket will not clear the dash. Otherwise you may bend that top tab. Remove the 2 torx screws from the mounting bracket and the switch will come out. Detach the wiring harness and remove the trim ring.
5) Now you are supposed to be able to remove the shaft by pressing a button on the bottom of the switch, Use pliers (not the knob) to get a good grip. Mine would not release, so I bought a replacement knob/shaft, and tossed the knob.
6) The aftermarket shaft is slightly bigger than factory. The trim ring would not slide over the shaft easily. I used a small drill the size of the hole and reamed the trim ring's central hole slightly larger. Otherwise the switch will bind up once installed.
7) Reassemble in reverse order. Use care to insure the switch is centered and the tab is in the mounting bracket slot before tightening.
8) When done, I found the new shaft was about an inch too long. Measure carefully and the shaft can be hacksawed to proper length w/o removing the switch.
Uhm.... You're responding to a post that's over 10 years old. That's not very useful.
