Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4WD Systems
Notices
4WD Systems Transfer Cases & Locking Hubs. Forum sponsored by The Shiftster
Post New Thread Reply
Thread Tools Display Modes
Old 01-02-2008, 08:18 AM   #1
Culprit
Culprit's Avatar
Year: 1995
Make: Ford
Model: Ranger
Culprit is on a distinguished road
Default Swapping to Manual Hubs in '95 Ranger
The Auto hubs in my 217,000 mile '95 Ranger are shot, so I'm going to manual hubs. I'm not building an off-road toy - this is my daily driver and I just want to get up my driveway when it snows.
Where can I get a set of hubs (and the new inner and outer nuts and lock ring/washer) for the lowest price?
I've done my homework and figured out what model hubs fit from what manufacturer, but all the parts stores and online places I've found want close to $200 for the hubs and conversion kit once you start factoring in shipping. My local junkyard doesn't have a set.
I even called the dealership to check on their prices, but the lady on the phone said she couldn't look up which hubs I needed unless I gave her my VIN (which I don't have on hand). She said there were too many different axle ratios and she needed to know which I had before she could look up the right hubs. That doesn't sound right to me.
Correct me if I'm wrong, but all I need are a set of hubs that will fit my Dana 35 axle shafts - regardless of what gears I have. Or am I missing something?
Semper Fidelis,
Culprit
Culprit is offline   Reply With Quote
Old 01-02-2008, 09:31 AM   #2
MAKG
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
MAKG will become famous soon enough
Default
You need hubs AND the spindle nuts.
And these are good candidates for junkyard hunts. Just make sure you clean them out real well and repack them before using them.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 01-02-2008, 12:48 PM   #3
bernerboy
bernerboy's Avatar
Year: 1986 1988
Make: Ford Ford
Model: Ranger Ext Bronco II
Engine: Both are 2.9
Class: both are 4X4
bernerboy is on a distinguished road
Send a message via AIM to bernerboy
Default Manual Hubs
Cullprit
I just order the conversion kit and hubs from a local WARN distributor. The hubs are 190.00 and the conversion kit is another 50.00. I like you looked locally and could find nothing so in the long run it is cheaper to just order it and get it done....
Good luck
Gene
bernerboy is offline   Reply With Quote
Old 01-02-2008, 03:50 PM   #4
racsan
racsan's Avatar
Year: 1993
Make: ford
Model: ranger s/c
Engine: 4.0/245 c.i.d.
Class: 4xford
Used For: gitten' it done!
racsan has a spectacular aura aboutracsan has a spectacular aura aboutracsan has a spectacular aura about
Send a message via ICQ to racsan Send a message via AIM to racsan Send a message via Yahoo to racsan
Default
mile marker hubs from autozone are cheaper,its been a year or so since ive gotten mine and ive had no problems from them, think the hubs themselves were around 120.
________
Acura RL
racsan is offline   Reply With Quote
Old 01-02-2008, 04:14 PM   #5
Culprit
Culprit's Avatar
Year: 1995
Make: Ford
Model: Ranger
Default
Thanks for the replies - and keep em coming!
$120 sounds like the lowest I've found thus far. I have a really hard time believing that my local junkyard doesn't have any - but that's what they said on the phone (they're not a u-pull-it place).
Old 01-02-2008, 09:25 PM   #6
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
Quote:
Manual hubs on D35s are not common, so it's very possible they are telling the truth (manual hubs & t-case was a "delete" option for the standard "Touch-Drive" crap during most of the entire time the D35 axle was used).
They very likely DO have the spindle nuts however, they may just not know it (nuts from most D44 axles (fullsize truck) with manual hubs also fit the D35).
Or you could spend $8 a side vs. $50 for Warns overpriced kit (see thread at the top of the forum here)
The D35 hubs themselves will likely have to come from Warn/Milemarker/Superwinch/etc.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 01-02-2008, 09:48 PM   #7
Thumper113
Thumper113's Avatar
Year: 1994
Make: Ford
Model: Ranger XCab
Class: 4x4
Used For: Flexing On Curbs At The Mall
Thumper113 is on a distinguished road
Default
The Warn hubs for Jeeps are $159.95
The standard Warn hubs are $151.95
Don't let the pics on their site fool ya, they are the hubs that'll fit a D35 TTB.
Don't buy the $50 conversion kit, check your local aprts stores like NAPA or if you have a $ Wheel Parts store near you, you'll likely spend under $25 for the hub nut kits.
You'll need two of these bags
__________________
94 Ranger 4.0 5sp.
6" Skyjacker Class II, 3" B/L
5.13's, Detroit Lockers at both ends
37x12.50 MTR's
Truck Pics
Here
Wheelin' Pics Here
Thumper113 is offline   Reply With Quote
Old 01-03-2008, 03:00 PM   #8
bernerboy
bernerboy's Avatar
Year: 1986 1988
Make: Ford Ford
Class: both are 4X4
Default
Culprit, I got my hubs and kit this a.m. and it took me all of 45 minutes to replace the auto lock hubs to manual. Forgot how good 4 wheel drives is suppose to work.
I checked Autozone too, they were not exactly sure when the parts would come in. The Warn distributor had them for me the day I picked them up at about 830 was in the garage (heated) at nine and out the door at ten and back to plowing the 16 inches of snow we got New Years Day.
Good Luck
Gene
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
