- Oct 16, 2007
- Prunedale CA
Hi, hope some one can help me. I have a 2.8 that I have recently done some work on. I put a full gasket kit on the engine with the exception of the head gaskets. Now I seem to be getting moisture in the crank case. I shows up on the dip stick and in the dip stick tube. It is never mingled in with the oil like real communication between the cooling and lubrication systems. I just get surface rust at the top of the dip stick and a small gob on the end of the dipstick. Again, the oil is clear and the moisture just seems to collect on the top of the dip stick and slowly meander (?) to the bottom of the stick. I have installed a new PCV and a new breather in the air filter. The PCV system seems to be working fine. There is always the possibility that there is a leak on the gasket when I installed the intake manifold. I also changed the water pump. I don't think there is any chance of communication between the water pump and the crank case is there? I consider my self to be a pretty good parts changer and take my time to get it right the first time...thus I have a little bit of difficulty thinking it is in the intake.....it is some where. I had the engine out of the pickup when I did all the work to it.
Thanks.
Eric <><
Thanks.
Eric <><
