Go Back   The Ranger Station Forums > Engine & Transmission Forums > Engine Conversions > V-8 Conversion Forums
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 05-03-2010, 11:47 AM   #1
Smokeyjoe09
Junior Member
Smokeyjoe09's Avatar
Model: rip RANGER EDGE
Engine: 4.0
Class: 4x4
Used For: daily driver
Smokeyjoe09 is on a distinguished road
Default 5.0 question
can it reach 250-300 hp mark with aftermark parts?
Smokeyjoe09 is offline   Reply With Quote
Old 05-03-2010, 12:06 PM   #2
Teddyzee
December 2011 STOTM Winner
Teddyzee's Avatar
Year: 1997
Make: Ford
Model: Ranger
Engine: 5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
Class: 2wd
Teddyzee has a spectacular aura aboutTeddyzee has a spectacular aura about
Default
Easily.
__________________
97 Supercab 5.0 H.O. EFI Tri-Y Headers T-5
DJM 5/8 Drop
Cal-Vu mirrors, Shaved badges. Explorer interior
18X9/18X10 Bullitt wheels (275/40, 295/35)
5.0 link
Teddyzee is offline   Reply With Quote
Old 05-03-2010, 02:11 PM   #3
LittleBigFoot
LittleBigFoot's Avatar
Year: 79-00
Make: Mostly Ford.
Model: Rangerish-Broncoish-Truggyish Thing.
Engine: Building a 408w
Class: 4x4 Extreme / Race
Used For: The 13th step of the 12 step program.
LittleBigFoot is on a distinguished road
Send a message via AIM to LittleBigFoot Send a message via MSN to LittleBigFoot
Default
Easily, as said above.
Search on line for dynos. You can plug in displacement, compression, valve duration, exhaust, weight, blah blah blah and it'll give you a rough estimate.
I'm building a 427w and shootin for 400 ft lbs of torque and it seems rather doable.
Find yourway to the mustang forums. You'll find a lot of 5.0 builds
__________________
Wheeler: Ranger With Some Stuff Done
DD/Tow Pig: 1972 F250 With Some Stuff Getting Done
LittleBigFoot is offline   Reply With Quote
Old 05-03-2010, 06:26 PM   #4
droptopfox
Junior Member
droptopfox's Avatar
Year: 1989
Make: ford
Model: ranger 5.0
droptopfox is on a distinguished road
Default
250-300 is just a decent set of heads a good cam some roller rockers and a intake and thats too the ground my truck makes just over 300 rw with gt40x aluminum heads e cam 1.7 rr motorsport airgap intake 670 holley threw an aod with a t5 it should be like 350rw and soon with a secret plan it will be like 400rw threw the aod
__________________
Lifes journey is not to arrive at the grave safely, in a well preserved body, but rather to skid in sideways, totally worn out, shouting Holy shit, what a ride!
THE HEARTBEAT STOPS HERE
droptopfox is offline   Reply With Quote
Old 05-03-2010, 06:57 PM   #5
baddad457
Year: 1989
Make: Ranger
Model: Supercab
baddad457 will become famous soon enoughbaddad457 will become famous soon enough
Default
Quote:
You can do that with the stock parts.
baddad457 is offline   Reply With Quote
Old 05-03-2010, 07:59 PM   #6
COPPERHEAD85
COPPERHEAD85's Avatar
Year: 85
Make: ford
Model: ranger
Engine: 302
Class: 4x4
Used For: Yard Decoration
COPPERHEAD85 is a name known to allCOPPERHEAD85 is a name known to allCOPPERHEAD85 is a name known to allCOPPERHEAD85 is a name known to allCOPPERHEAD85 is a name known to allCOPPERHEAD85 is a name known to all
Default
Mustangs & Fast Fords did a junkyard build using a 5.0HO out of a Tbird,Duraspark Dizzy,210cc Pro Comp Alm. heads 70cc exhaust ports with 2.02/1.60 valves flowed at 260 cfm on intake and 177 cfm exhaust (they also came with studs and guide plates) about $600 a set on eaby.
They did mill the heads to 60cc chambers witch pushed the comp. ratio to 9.7:1.Pro Comp Roller Tip Rockers ($55).A Track Max (Trick Flow) 0.499/0.510 lift split,221/225 duration split with 112 lobe centers with factory roller lifters,A pro Comp Parker Funnel Web intake ($125) with a used Holley 750 double pumper.
It made 399 Hp at 6,000 RPM and 363 ft.lbs at 5,200 RPM's on an Engine Dyno.
They spent $1,064!
That was with 0 rebuild on the bottom end of a salvage yard 5.0HO.
__________________
Stabbings aren't funny
Beatings aren't funny
Clowns aren't funny
But Beating and Stabbing a Clown...Thats Funny!
COPPERHEAD85 is offline   Reply With Quote
Old 05-03-2010, 08:53 PM   #7
Smokeyjoe09
Junior Member
Engine: 4.0
Class: 4x4
Default
would efi help ?
Old 05-03-2010, 09:01 PM   #8
droptopfox
Junior Member
droptopfox's Avatar
Year: 1989
Make: ford
Model: ranger 5.0
Default
n/a at wot a carb makes more power than efi
__________________
Old 05-04-2010, 07:21 AM   #9
COPPERHEAD85
Year: 85
Make: ford
Model: ranger
Engine: 302
Class: 4x4
Default
I really don't have a problem with EFI but I believe it would add more $$ and time tuning to the build.
What do I know...........I still run carbs on everything but the wifes Jeep....lol.
__________________
Clowns aren't funny
Old 05-05-2010, 02:06 PM   #10
mlw20lu
Junior Member
mlw20lu's Avatar
Year: 2001
Make: ford
Model: ranger edge 3.0
mlw20lu is on a distinguished road
Default
efi does add more money.. if you check out my build im shooting for about 275 hp with efi. but i have a tuned ecm also
mlw20lu is offline   Reply With Quote
Old 05-05-2010, 02:33 PM   #11
dirtydeeds
Year: 03
Make: toy
Model: tun
dirtydeeds is on a distinguished road
Default
They're right, 300 is easy to the wheels. EFI would cost a little more but the fuel economy would be a little better. Drive ability would be a little better as well. Plus you could go smog legal if that matters.
dirtydeeds is offline   Reply With Quote
Old 05-05-2010, 02:53 PM   #12
fordmike1
Year: 1994 & 1983
Make: Ford
Model: Ranger
Engine: 5.0l
Class: 2WD Street
fordmike1 is on a distinguished road
Default
Quote:
X2
We took a stock 89 mustang bottom end and cam with a set of Explorer GT40p heads, Explorer intake and T-body, Mac long tube headers with a C4 trans 2500 converter and 3.73 gears and run 13.20. thats about 330hp at the flywheel. All this was done in a 91 Mustang coupe weighting 3200 with driver.
__________________
1/20/13
Change we all can belive in ! !
fordmike1 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
