Anyone put a carb'd 302 in a BII?
87dytnajeff
15+ Year Member
If you have i'd love to hear about your process and what you had to do the line things up and make them fit. I'm getting ready to put a 302 in my BII, and need a little help.
What transmission should i mate with it?
Can i keep my stock manual shift transfer case? Or do i need to upgrade to a more heavyduty one?
Do i need to change the rearend?
Can i keep the front twin beam 4x4 axle?
I can handle putting the engine in, it's the driveline i'm not sure about.
Any help is great help
v-8 BII
Carb'd 302
C-4 Auto trans
to keep the trans case, which is plenty strong for a 302, use the Advance Adapter.... adapter, bout $450 from them
Do yourself a favor and swap out the stock diffs and get the Dana 35/8.8 stuff from an explorer, pretty much a straight up swap
Make sure to check out the tech library here, lot's of good stuff.
Ranger - broncoII same thing except driveline length lots of information on rangers I have seen with 302 conversion
Even better then paying $450 for an adapter, find a C-5 Transmission from an 85-86 Auto ranger or BII from a junk yard,(About 200bucks.) Pull the tail shaft and bolt it up to your C-4....
Keep your crossmember/Transfercase and get the strength of a C-4. Also keeping your drivelines. Would trash the dana28/7.5 and grab a set of Explorer axles.(35/8.8 31spline.)
