| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Junior Member
I have a 2003 B2300. It was purchased with a manual 5-speed with the intent of having a simple low maintenance vehicle.
I baby my truck with the intent of getting at least 120K out of the clutch. Then one day my clutch pedal goes to the floor. Easy fix right? I probably let the hydraulic fluid get low. Fine, add fluid, it runs out of the bottom. (crap) I limp home, and attempt a fix, it shouldn't be too difficult right? Probably a slave cylinder. $150 fix, quick swap, ready by morning. Repair manual, step #3: Remove transmission.... WTFH?! Slave cylinder where I can't get to it? WHY?!?!? Who the &*&(* designed this?!?!? Is there a purpose to making a transmission like this? (except to make more money?) It's cost me a whole lot of time and money to fix this thing, and I am a whole lot of pissed off. (rant off) thanks for listening (reading) CE |
Tweet
#2 |
February 2010 OTOTM Winner
Year: 2001
Make: Ford
Model: Ranger
Class: Snow Wheeler/DD
Used For: Pickin' up chicks.
Rep Power: 13 ![]() iTrader: (0)
hahahahahaha....welcome to manual transmission ranger ownership. ain't looked into these trucks much have ya? lol.
Technically, fixing the truck is an under $100 fix. That's if you do the work yourself. Only need the slave. But it is smart to go ahead and do the clutch with that many miles on it. lol. Be sure to grab a lifetime warranty slave...that way you only pay that 100 when it takes a sh1t on you in 30k. I'm on #5 but my trucks a little different beast than yours. lol. |
Tweet
#3 |
Junior Member
Meh, researched a bunch about the truck, never saw the slave cylinder as the weak point. (oopse).
I'm guessing there is no alternative but to get proficient at dropping the transmission, unless you know of a better drop in transmission. And if those are the only options, then this is turning out to be a throw away truck. Man, what a waste. |
Tweet
#4 |
Year: 2012
Make: GMC
Model: Sierra 1500
Engine: 4.8L
Class: 4x4
Used For: Around the farm, Daily Driver
Rep Power: 9 ![]() ![]() iTrader: (0)
i have a 136,000 miles on my ranger. Never changed the clutch disc, only changed the slave once. i wouldn't call that a throw away vehicle. theres no reason the hydraulic/clutch unit shouldn't last over 100k.
Tweet
#5 |
Year: 1994
Make: ford
Model: ranger
Engine: 4.0
Class: 4x4
Used For: everything
i have 272k on my truck and its only been replaced twice.
__________________
94 ford ranger 4.0 5 spd with 260k Twin Sticks and 31s straight pipes |
Tweet
#6 |
Junior Member
Year: 1992
Make: ford
Model: ranger
Engine: 2.3
Class: 2wd
Rep Power: 12 ![]() iTrader: (0)
The slave cylinder issues and the leaking shift rail plugs are the only common issues that plague the M50D, at least that I've heard or experienced. Despite these issues, they are far better than any automatic trans put in a ranger. Your intent of purchasing the five speed and having a low maintenance vehicle is right on track. It's the same decision I made when buying my ranger. If it would have been an A4LD, I would have walked away.
Tweet
#7 | |
Year: 1988
Make: Ranger
Model: 4x4 2.9l 5speed
Engine: 2.9
Class: 4x4
Used For: getting stuck
Rep Power: 11 ![]() iTrader: (0)
meh, just pull up your skirt and fix it.
__________________
how to pull codes on the EEC-IV. http://www.therangerstation.com/tech_library/OBD_I.html do it! Quote:
Tweet
#8 |
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
Rep Power: 47 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (18)
trust me, it is a bitch to get to, but you don't need to do it often.
AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun. |
Tweet
#9 |
Year: 2012
Make: GMC
Model: Sierra 1500
Engine: 4.8L
Class: 4x4
actually, since i'm assuming its not a 4x4, its extremely easy to drop that tranny.
Tweet
#11 |
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Engine: 4.0-5.2 Turbo
Class: Real 4WD, 3WD.
Used For: Going where I point it-Going fast
Rep Power: 24 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
My Dakota has an external slave cylinder
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs 95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
