Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 08-17-2007, 01:48 AM   #1
SuperRob
SuperRob's Avatar
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Used For: exporting Alberta Dirt into BC
SuperRob is on a distinguished road
Default What REALLY is considered lift height?
So a buddy and I were talking today about lift height.
When you're describing a lifted truck, does the increase in height gained SOLELY by bigger tires count towards the height of 'the lift'?
Increasing tires from a 28" to a 35" has a total difference of 7 inches, split the difference, for 3.5 inches of increased truck height (And, no, we're not getting technical about the bottom of the tire having a lower profile due to vehicle weight...its not significant in this case)
Assuming said truck has a 3 inch body lift, and a 6 inch suspension lift, should this truck be referred to as being lifted 9 inches, or 12.5"? And if you deem that the tire lift should count towards the total lifted height, would it then be safe to say that, 'That truck is lifted 12.5"'? (Where lifted 12.5 inches is an adjective?)
THEN, could you also say, 'That truck has a 12.5" lift!", or would be be then said that, 'That truck has a 9" lift!'? (Where 'the lift' is a noun, and tires are not actually a part of the lift)
Yes I have too much time on my hands.
Anxiously awaiting replies.
__________________
Will - 'If I were a shit eating dog, there would be nothing left but your boots.'
1989 Ranger XLT 4x4
2.9l, Mistubishi 5 speed, Dana 35 (3.73) Front End, 7.5" (3.73) Rear End
F150 Coils with 1 1/8" Spacer, Explorer Leaf Pack with extra Main Leaf, Belltech 6400 Shackles
SuperRob is offline   Reply With Quote
Old 08-17-2007, 02:01 AM   #2
Redneck Cowgirl
Junior Member
Redneck Cowgirl is on a distinguished road
Default
the total lift that can be counted is for example:
3" body lift, and a 6" suspention lift = 9"
One could say they have 9" lift.... the size of the tire does not count towards the "lift" ones truck has... Its could count towards clearance looking at the diff.... or frame hight, but does not count as part of there total "lift"
This is why in almost every converstation everyone who wheels has includes both of theses questions:
Is it lifted? How much?
AND
What size of tires you running???
Redneck Cowgirl is offline   Reply With Quote
Old 08-17-2007, 03:21 AM   #3
TRUNK_MONKEY
Junior Member
TRUNK_MONKEY's Avatar
Year: 2002
Make: jeep
Model: wrangler
TRUNK_MONKEY is on a distinguished road
Send a message via Yahoo to TRUNK_MONKEY
Talking meh
i'd call it,from where it was (stock) to where it is now.by any means. and it really matters not anyway,as long as your parts dont rub and cut tires up,you are fine.
lift means nothing anyway.
how many lifted rigs do you see with 2 inches of u bolts pointing to the ground?seriously,i think people need to devote some time to "de-horning" the bottom of the trucks. lots of junk down there waiting to grab a rock or log and make ya really mad!!
__________________
when you have to shoot--shoot,dont talk
tuco
http://staythetrail.org/
TRUNK_MONKEY is offline   Reply With Quote
Old 08-17-2007, 04:15 AM   #4
PARKINGLOT
PARKINGLOT's Avatar
Year: 1995
Make: Jeep
Model: Grand Cherokee
Engine: 5.2
Class: 4x4
Used For: haulin' groceries & wheelin'
PARKINGLOT is on a distinguished road
Default
tires don't count...you need the lift to fit bigger tires (usually, although that could mean my stock BII was lifted 1" from the 31's on it...lol)
the lift gives you height to run bigger tires and give you a better approach, departure, and break-over angle, and the tires give you more clearance under the diffs...
__________________
RIP Matt C - turbonator/sohc86 :(
Switched to the dark side - 95 ZJ 5.2 with some stuff.....
"I don't break shit, I just test it's durablity"
Formerly GONRACIN, Member #166, Join date 30-July 04
PARKINGLOT is offline   Reply With Quote
Old 08-17-2007, 09:19 AM   #5
JohnnyO
Clean And Articulate
JohnnyO's Avatar
Year: 2008
Make: Ford
Model: Sport Trac
Engine: 4.0
Class: 4x4
Used For: Daily Driver
JohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to behold
Default
I would count the suspension and/or bodylift but not anything gained by the tires alone. .02.
__________________
Steeler Nation does not have to travel. We're already there.
"It is not the multitude of ale houses that occasions a general disposition toward drunkenness among the common people; but rather disposition arising from other causes necessarily gives employment to a multitude of ale houses." -- Adam Smith, 1776
JohnnyO is offline   Reply With Quote
Old 08-17-2007, 09:22 AM   #6
DK27
DK27's Avatar
Year: 1994
Make: Mazda
Model: B4000
DK27 is on a distinguished road
Default
I would count the tires as gained ground clearance I believe.
__________________
1994 Mazda B4000
4" SkyJacker Lift | JL Audio System
31" Tires | Single Piece Drive Shaft | Other Goodies
2004 Acura RSX
5 Spd Base 2.0L
Stock for now
Quote:
Originally Posted by JohnnyO View Post
If elected, I'd be screwing every babe in D.C. that weighed less than me.
DK27 is offline   Reply With Quote
Old 08-17-2007, 09:46 AM   #7
High Desert Ranger
High Desert Ranger's Avatar
Year: 1987
Make: Ford
Model: Ranger
High Desert Ranger is on a distinguished road
Default
It is the height of the suspension lift and the body lift and not icluding the height of the tires. Namely because the first 2 increases in height are structural changes to the the truck and tires a dress up change. One could put 12" of lift in the suspension and body of a truck and go smaller on the tire size. Would that mena that the decrease in the tire size counteracts the amount of the lift nope. Namely because wheels are very easy to change and I could quite literally change tire size every 30 minutes and have upwards of 30+ tires put on the vehicle in one day but that still doesn't count towards lift height.
Besides if you this about it; it is suspension Lift and body Lift and you never say tire Lift so in Lift height it is only suspension and body that counts.
High Desert Ranger is offline   Reply With Quote
Old 08-17-2007, 09:51 AM   #8
MAKG
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
MAKG will become famous soon enough
Default
The tires change the clearance and the bumper height. They do not change the lift.
Note that some "lift laws" really regulate the bumper height.
Honestly, when designing a truck for the trail, the lift doesn't matter. Only the clearance (and a few other issues like overhang and wheelbase).
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 08-17-2007, 11:52 AM   #9
arrabil
Year: 1990
Make: Ford
Model: Bronco II
arrabil is on a distinguished road
Default
You can't use the tire because the flex IS significant. If you're measuring in half inch increments, certainly your tires compress 1/2" at the bottom at 28psi. And if you put less air into them that number can change to 1.5" quickly.
Yup. 30" for the horizontal parts of the bumpers to the ground, body lifts no bigger than 3", and the tires tucked into fenders are the only real requirements in PA.
__________________
1990 Bronco II 2.9L M5R1 BW1354e 5.13 D35/arb 8.8/arb 35s +6". The Deuce.
2006 F-150 5.4L 4R75E BW4406e 3.73 8.8 9.75/ls 33s.
arrabil is offline   Reply With Quote
Old 08-17-2007, 04:56 PM   #10
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
I've generally always excluded the tires from "lift" also.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 08-17-2007, 05:29 PM   #11
brendank
It's only money...
brendank's Avatar
Year: 1993
Make: Ford
Model: Ranger
brendank is on a distinguished road
Default
Yup. Tires don't count.
__________________
Blue 93 Ranger 4.0L 4x4 5spd, 38.5's on 16x10's
EB coils, 6" Skyjacker Leafs, Belltech 6400's, Bilstein 5150's
Fullwidth D60, Lockright, 5.38's, Dedenbear C's
14BFF, 5.38's, Detroit, Disc Braked
3" B/L, Dual batteries, 9500lb winch, Bushwacker cutouts
brendank is offline   Reply With Quote
Old 08-18-2007, 02:51 AM   #12
SuperRob
SuperRob's Avatar
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Default
Thats what I thought too....Tires dont count
__________________
1989 Ranger XLT 4x4
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
