Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 03-20-2010, 04:07 AM   #1
Twister
Twister's Avatar
Year: 1985, 1987
Make: Duh
Model: Bronco II, Bronco II
Engine: 2.8L, 2.9L
Class: 4x4, 4X4
Used For: DD and occasional offroad
Twister is a jewel in the roughTwister is a jewel in the roughTwister is a jewel in the rough
Default Running Hot
Ok, so i have an 85 B2. It started to run hot about 2 months ago and i have been trying to fix the problem.
I have replaced the fan clutch, water pump, t-stat and all the belts with no results.
So do you think i should get a new rad?
And how hard is it to put the 4L one from the xpolder in my B2?
thanks
Twister is online now   Reply With Quote
Old 03-20-2010, 08:39 AM   #2
lil_Blue_Ford
lil_Blue_Ford's Avatar
Year: 95
Make: Ford
Model: F-150
Engine: 4.9L
Class: 4x4
Used For: Work
lil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to behold
Send a message via AIM to lil_Blue_Ford
Default
Sure it doesn't have a cracked head? Or a coolant leak somewhere?
My choptop had a coolant leak from the heater core, but it was strangely leaking outside of the cab a the firewall, which made it a bit difficult to discover. I managed to crack a head in the process of going nuts looking for the leak.
Of course, if you have the 2.8, you probably haven't cracked a head.
If you have the 2.8L, I have no idea as to if the rad out of a 4.0L will fit fine or not. If it's a 2.9l motor, then the 4.0L rad is a drop-in swap, but you may have to change the lower water hose.
a 4.0l swap on a first gen BII is not exactly easy. I started one in my 88 a couple years ago and never finished because I ended up in wiring hell. I couldn't find the wiring diagrams I needed to finish it. Of course, if you're not opposed to swapping to a newer dash, it would be considerably easier, there would be very few wires to be spliced and all in areas where it's not hard to get the wiring info.
__________________
"lil Blue" 2000 Ranger Supercab xlt: 3.0L, 5-spd, 2wd
"S**tbrick" 1988 Bronco II Eddie Bauer: 4.0L, auto, 4x4
1989 Bronco II choptop: 2.9L, 5-spd, 4x4, 7" lift, locked f/r, 33's
"Phoenix" 1986 Bronco II xl: 2.9L, auto, 4x4 (future trail toy)
1989 Ranger parts donor: 4cyl, manual trans, 4x4
Quote:
Originally Posted by JohnnyO View Post
Some people are too stupid to be in management. That's why they keep getting promoted.
lil_Blue_Ford is offline   Reply With Quote
Old 03-20-2010, 09:26 AM   #3
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
How much coolant is in it?
Are you sure you aren't leaking?
What is the condition of the coolant?
If all coolant conditions are ok, when was the last time the carb was checked/adjusted?
A lean condition can cause the engine to run hot.
I know the 2.8 has an electronic feedback carb, but I'd guess it still has some sort of adjustment. I'd try to richen it up a bit.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is online now   Reply With Quote
Old 03-20-2010, 02:30 PM   #4
Twister
Twister's Avatar
Year: 1985, 1987
Make: Duh
Engine: 2.8L, 2.9L
Class: 4x4, 4X4
Default
Well i have the 2.8, and have no idea as to ho to check if i have a cracked head.
My lower rad hose was leaking like crazy but i fixed it awhile ago. On the out side that's the only leak i had. I dont seem to be losing any coolant.
With the carb thing, how can i tell if i am running lean or not, and if i am how do i adjust it?
I am running out of things to replace with the coolant system, about the only things i havent replaced are the heater core and the rad. I have flushed both of those fairly well in the past month.
I am stumped.
Old 03-21-2010, 12:27 AM   #5
Robert_1967
Robert_1967's Avatar
Year: 1988/1989
Make: Ford
Model: Ranger Supercab/BroncoII
Engine: 302/2.9
Class: 2wd Street/4x4 street
Used For: Soon to be hot rod/Daily Driver
Robert_1967 has a spectacular aura aboutRobert_1967 has a spectacular aura about
Default
my guess would be a cracked head or bad head gasket.
look for water in the oil, and oil in the water, also if it blows bubbles when running and the rad cap is off.
Robert
__________________
All Truths are Known upon Death.
If I can't work on my Ranger or BroncoII, I rather be fishing.
If Facebook, MySpace, and Twitter were all destroyed, 90% of teens would go insane.
Robert_1967 is online now   Reply With Quote
Old 03-21-2010, 11:31 AM   #6
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
You can also pull plugs and look for one that looks steam-cleaned. If it's cracked and leaking into a cylinder it will steam clean the plugs when they fire off the fuel.
__________________
Old 03-21-2010, 03:36 PM   #7
Twister
Twister's Avatar
Year: 1985, 1987
Make: Duh
Engine: 2.8L, 2.9L
Class: 4x4, 4X4
Default
Robert
The rad will blow bubbles?
Old 03-21-2010, 04:06 PM   #8
kimcrwbr1
kimcrwbr1's Avatar
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Used For: DD tow boat
kimcrwbr1 is just really nicekimcrwbr1 is just really nicekimcrwbr1 is just really nicekimcrwbr1 is just really nice
Default
When you flushed the readiator did you back flush it disconnect both hoses plug the lower one and run the hose full blast if you have a long hose crimp it to get the most pressure you can also fill the radiator with easy off oven cleaner let it set a few minutes the flush it good do that both ways a couple of times probably better to take it out for that and be careful as you know it burns especially the eyes.
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 03-21-2010, 04:54 PM   #9
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Quote:
when you take the cap off you will see little bubbles coming to the surface because a cracked head or gasket will allow gases from the cylinder into the cooling system and then they come out at the cap.
__________________
Old 03-21-2010, 05:04 PM   #10
Robert_1967
Year: 1988/1989
Make: Ford
Engine: 302/2.9
Default
Quote:
Thank you
Robert
__________________
Old 03-21-2010, 06:05 PM   #11
Twister
Twister's Avatar
Year: 1985, 1987
Make: Duh
Engine: 2.8L, 2.9L
Class: 4x4, 4X4
Default
Well i drove it till it hit the bottom of the R in Norm, i took the cap off and i did not see any bubbles. I gave it a little gas after i checked it with the cap off and still no bubbles.
Also what would cause your car to raise in temp in you turn the heat on. I was driving it and it hit the N in Norm, so i decided to kick the heat on and it went up faster.
Old 03-21-2010, 06:09 PM   #12
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Suspension of the normal operation of the laws of physics?
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
