- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
ok, ever since my body swap my brakes have been lacking, I've bled them many many times, I've replaced both calipers, both cylinders (and one just went out again), both front brake lines and just tonight the master cylinder.
the symptoms are soft pedal, goes about 3/4 of the way down before you stop, every time I bleed the system I get air out it seems, how the heck is it getting in? I also have the RABS light on, thought itwas just the sensor on the axle, which was trashed when the spider gear lost a tooth, but I replaced it and reset the computer and it's still on. the back brakes will usually lock up just fine and I might get one front tire to lock up if I'm lucky. is there some special way to recenter the valve or whatnot?
what am I doing wrong? I'm about out of ideas. yes I bench bled the master cylinder following the directions that came with it. I've been gravity bleeding for the most part, try to get help when I can. right now it's sitting sucking fluid to the passenger caliper with a bubble about every inch, been doing it for about 15 minutes now...
I'm at my wits end, and am finally asking the people with more experience than I...
