#1 Torsion bar Part #'s. 99% sure
fitn217
15+ Year Member
NYC
While searching on this site the part #'s for the Code1 torsion bars were never mentioned. I have an 04 FX4 and my Ranger came with mid level B torsion bars. PN: F57A*5B326*BC
In a few threads on this site it was mentioned that you needed the VIN of a Level II Ranger or Sport Trac(two vehicles that came standard with # 1 bars) to acquire these parts from Ford.
This is not true!!
I got my part #'s from this site:
http://www.fordparts.com/Default.aspx
This thread is also a good thread on torsion bars, and where I discovered some info that really helped me:
http://www.therangerstation.com/forums/showthread.php?t=49018&highlight=torsion+sag
I went to the parts counter @ my local dealership and told the guy I wanted Code 1 torsion bars...he asked for my VIN and I just told him I want stiffer torsion bars than the ones that were original to my truck. I then told him the part #'s that I wanted:
Passsenger:F67Z*5B326*FA
Drivers: F67Z*5B326*FB
Installation was easy with a 2 jaw gear puller I bought from the Harbor Freight store. It's not listed on the website (I got it @ the actual store)but it's a kit of 3 2jaw gear pullers for 19.99.
Here are the instructions I used as a guide during the installation:
http://www.readylift.com/files/instructions/66-2020_Instructions.pdf
I'm 99% sure that this info is correct....maybe if someone with a Level II Ranger can check his torsion bars for the part # we can confirm this. Or if anyone with further knowledge could confirm or prove this thread wrong that would be great.
Good luck........
F67Z#5B326#FA Pass side bar
F67Z#5B326#FB Drivers side bar
These are the #1 t-bar part #'s
I'm pretty sure you got A rated bars which are the next step up from B bars. A rated bars are on explorers not rangers. Rangers are either 1, B or F.
So you upgraded just not the stiffest you can get
It's listed on the Ford website site as A....for a Ranger....there is no mention of F67Z...I listed the part #'s according to the Ford website as I thought this would confuse some.
On my receipt it says
F67Z*5B326*FA
F67Z*5B326*FB.
On the bars it says both A in one spot and Z in another........on Both bars.
If you check the Ford site and plug in Ford RANGER and the appropriate info there is no mention of A bars...just F,B and Code 1's.
There are a lot of different ratings of t-bars because there are different vehicles that use them like the explorer, mountaineer, sport trac, ranger
it ranges from 1,2 A, B, D , E , F in order. 1 being the stiffest, F being the softest.
but like I said rangers only use 1, B, F
the part # I posted above is the correct #1 part number
Ok great!!!
Just happy that the correct part #'s are out there for anyone who wants them.
Thx for your help Camodown!!
About how much do they cost?
One of mine is bottomed out and other one aint. Will they fit a 98 ranger 4x4?
I got mine for $75 each
sweet thanks! And the code 1's fit alright? no problems?
The facts as I know them - your milage may vary.
Funny I should find this thread today...
I had been to my local junk yard looking at t-bars on Rangers and Explorers today. There was a Ranger that had Code #1 on the door and had t-bars that said A on the front of the t-bars. There was an Explorer that had Code #1 on the door and also had t-bars that said A on the front. (Letter code on the rear of the bars were different - I dont know what those would mean).
I had ordered new Code1 t-bars from Tascaparts.com last week (it even said "Code1" on the part description) and arrived home today to find UPS just dropped them off. The new bars I got said A on the front.
The numbers I order were F67Z 5B326 FA (right) and F67Z 5B326 FB (left). The tags on the bars I got had those numbers (+ the "*" as indicated).
The price I paid was $74.14 left, 74.76 left + $13.40 shipping.
I had also taken out my old t-bars today - Code F on the door, F on the bars. Looking at the new ones Im sure they will fit, but I should know for sure tomorrow...
BTW, I had good results researching this subject at explorerforum.com.
So i reckon the A and 1's are the same? Weird...
Let me know how they fit! Did you order yours from ford and somewhere else? I couldn't find them thru ford's website
Got R Done.
They fit fine. BTW, It would be hard to swap right and left as they are different lengths.
I ordered mine from TascaParts.com using the part numbers above. I called first to make sure he had them - he said not in stock but he called his supplier (manufacturer in Detroit) and said he would have them in 4 days and would ship then, and thats exactly what happened. So I had them in about 8-9 days.
Installed, I had to adjust them almost the same as my old ones (they were maxd). I could probably get another inch but that'd be too much - gives me some to gain if it starts sagging again.
Just for fun I measured the diameter at about the middle of both. The 1/A was about 1.10" while the F was about 1.03". But Im guessing there is other factors that determine stiffness besides the physical size.
Overall Im happy with them. They are not as bouncy as I feared, but then I have more weight than normal. My dad has a regular cab 2wd stepside ranger with "1" code coil springs and it gets tough on the back roads (but feels gooood in the turns :). Mine is firm but smoother than his.
was there enough bar to level it out? Thats all i'm looking for.
I'm a lil worried about tackling them as I have never messed with torsion bars but once. (when I straight axled my yota, torch cut them right out)
You may want to grab a coffee for this..
This depends on many factors... Mostly on how much difference you have now. Depending on options and/or wear over time, there will be a difference among our trucks. Torsion adjustment can raise the front up to 2 inches (or more if you feel lucky or can afford the associated repairs). So if your rear is 2 inches or less above your front then yes... maybe.
Torsion adjustment raises (or lowers) the bias - the starting point for suspension travel. This is what lifts (drops) the front of your truck. How far it goes up or down from there due to speed/terrain depends on the spring rate - which is the "size" of the bar. 1/A is the stiffest rate, not the highest bar. You can usually get more height with a stiffer bar because the (given) weight of the truck will not depress the suspension (from its bias) as much to start with.
Like I said, changing the bars did not give ME alot of extra height, but I wasnt looking for all that. I got my height years ago with my original bars. I believe they sagged a little over time but Im not really sure. I raised a little at first, then some more. Bigger tires needed a little more, then eventually they were maxed but I still had enough height. After the bar change I still had them almost all the way up but they dont bottom out and there is a little adjustment left if they do sag in the future (but I dont think they will as much as the smaller bars).
So to answer your question, Yes/No. It leveled it out, until I put air back in the rear air bags to raise it to the original "rake" (Im old school :)).
