doors...bummer
willievhook
Toledo, Oregon
Okay, tonight me and a couple of my buds were out trailriding, and I was backing up to turn around. Because of my window tint I can't see too well out of my back window, and i dont really use the mirrors, so I just open the door part way and look out it. Well, the bottom of my door got caught on a stump, and bent my door forward. Had to beat on it with an ax to get it to shut, so I need a new one.
My question is, what kind of doors will fit? I have a 93 extended cab
Also, how hard would it be to upgrade to electric locks/windows?
Thanks in advance
you should be looking for doors off from a ranger from 93-97, as they are all the same. as for the power window upgrade i would say as long as you have the wires going into your existing door it shouldnt be too big of a deal, and even if you dont you could trace the wires back to a plug inside the interior when you find the donor truck and then check the same spot in your cab to see if you have the plug to plug into.
